Pyportal boot
Pyportal boot
by TWDM on Thu Jan 23, 2020 11:04 am
Using good cables(3), ie work with Arduino. no amount of double clicking gets the portal recognized as a USB device. Have tried an apple, windows 8 and 10(returns message device no recognized) , two pi's and a lap top running Ubuntu. When plugged in the code runs and returns a message to edit the secrets file. Have read and tried various FAQ's and trouble shooting suggestions, but nothing. Any help or suggestions would be appreciated.
TWDM
Re: Pyportal boot
by dastels on Thu Jan 23, 2020 11:28 am
Read through https://learn.adafruit.com/adafruit-pyportal. That will give you what you need to get up and running with your PyPortal. Specifically in response to the message you are seeing: https://learn.adafruit.com/adafruit-pyportal/internet-connect.
dastels
Re: Pyportal boot
by TWDM on Thu Jan 23, 2020 11:56 am
I am stuck at the first step on six machines the pyportal is not recognized at a USB device. I have no access to PORTALBOOT. Again several computers, multiple cables. The instructions suggest that using a apple computers is the most straight forward, but no luck there either (the apple is not mine and not usually available).
TWDM
Re: Pyportal boot
by dastels on Thu Jan 23, 2020 12:20 pm
Ah.. so you get the "secrets file" message on the PyPortal display, and not a REPL connection?
If you inspect the USB connector, is there any visible damage? Can you post a clear photo of that area of the board?
dastels
Re: Pyportal boot
by TWDM on Thu Jan 23, 2020 12:40 pm
Pictures attached
20200123_110957 (2).jpg (330.69 KiB) Viewed 159 times
20200123_110926 (2).jpg (845.73 KiB) Viewed 159 times
TWDM
Re: Pyportal boot
by adafruit_support_carter on Thu Jan 23, 2020 1:34 pm
Do you still have access to the Ubuntu laptop?
When you double press reset, what does the red LED next to the micro USB connector and the RGB LED next to the reset button do?
Re: Pyportal boot
by TWDM on Thu Jan 23, 2020 1:41 pm
neopixel, steady red, led by usb blinking, on windows, message displays USB device not recognized
TWDM
Re: Pyportal boot
by adafruit_support_carter on Thu Jan 23, 2020 1:53 pm
OK. Thanks for verifying. That's expected behavior for a USB comm issue. The photos are great. If it's hardware related, it'll most likely be on the pins here:
which can't quite be seen in that photo. If you can post another, that would be great.
And just to be sure - this is a new PyPortal?
Re: Pyportal boot
by TWDM on Thu Jan 23, 2020 2:05 pm
portal in new, arrived from you earlier this week
let me know if this photo is ok
20200123_124245 (2).jpg (235.1 KiB) Viewed 151 times
TWDM
Re: Pyportal boot
by adafruit_support_carter on Thu Jan 23, 2020 2:43 pm
Thanks. That photo is excellent. And that connector looks fine. Really weird. Not sure what is going on here. We can try a replacement and see what happens.
Send an email to support@adafruit.com with a link to this thread and your order number and they can send you a replacement PyPortal.
Re: Pyportal boot
by TWDM on Sun Jan 26, 2020 9:01 am
New board worked right out of the box. Thanks.
TWDM
Re: Pyportal boot
by adafruit_support_carter on Mon Jan 27, 2020 12:58 pm
Excellent. Glad it worked. Thanks for letting us know. Have fun!
Re: Pyportal boot
by TWDM on Thu Feb 13, 2020 2:14 pm
After receiving the replacement I ordered two more. Tested them when I got them. Edited secrets file to get quotes running. Today just went to install the second of the two newer Pyportal 's in a newly printed case. When I went to program I couldn't get it into boot loader mode. Tried several times with three cords, no much and now it doesn't start into the quote program, just red led and neopixel.
Any suggestions would be welcomed.
TWDM
Re: Pyportal boot
by dastels on Thu Feb 13, 2020 6:24 pm
I've found that occasionally it needs to be double-reset while trying to upload. I've also had success with installing CircuitPython, then back to Arduino.
dastels
