si4713-fm transmitter no rds on message
by justforfun on Fri Jul 31, 2020 10:54 am
hi
I recently purchased the si4713-fm transmitter on https://www.adafruit.com/product/1958
and I have a problem
I uploaded the adaradio program with ought changing anything and the serial monitor says
Adafruit Radio-si4713 Test
Set TX power
Tuning into 102.30
and then nothing happens
so I tried changing the station to transmit on
nothing
I would like to use this so any help would be appreciated
justforfun
Re: si4713-fm transmitter no rds on message
by mikeysklar on Fri Jul 31, 2020 12:29 pm
Hi justforfun,
It looks like you wiring is reasonable. Assuming your UNO R3 clone works like an arduino with the same pin numbers there is probably no issue there for the SCL / SDA / CS.
Are you toggling the RST line on startup?
https://learn.adafruit.com/adafruit-si4 ... rt/pinouts
RST - This is the Reset pin. You must have this pin toggle before starting to communicate with the chip. When at logic 0, the chip is in reset.
mikeysklar
by justforfun on Sat Aug 01, 2020 10:23 am
how do I toggle the RST
justforfun
by mikeysklar on Mon Aug 03, 2020 4:36 pm
Hello justforfun,
In our guide we tie RST to pin 12 of an Arduino.
Connect the RST pin to digital 12 - you can change this later but we want to match the tutorial for now
I do not see your si4713 RST pin hooked up in the photos youu provided. The example included with the si4713 library will take care of it from there.
#define RESETPIN 12
https://raw.githubusercontent.com/adafr ... aradio.ino
mikeysklar
by justforfun on Tue Aug 04, 2020 2:43 pm
the RST pin is connected to digital twelve on Arduino and it is in the pictures
justforfun
by mikeysklar on Tue Aug 04, 2020 4:23 pm
Sorry, I was struggling to see the pin alignment with the labels and the breadboard in your photos.
Have you tried using a multimeter to check each connection. Just to confirm the wires and breadboard are making a full connection. The wiring is rather straight forward and it look like you have everything in place so it might be a loose connection between the UNO and the FM Radio.
Also, I would be curious if you uncomments the RPS Scanning code in the example if anything appears on the serial console.
  // Uncomment below to scan power of entire range from 87.5 to 108.0 MHz
  for (uint16_t f  = 8750; f<10800; f+=10) {
   radio.readTuneMeasure(f);
   Serial.print("Measuring "); Serial.print(f); Serial.print("...");
   radio.readTuneStatus();
   Serial.println(radio.currNoiseLevel);
mikeysklar
by justforfun on Sat Aug 08, 2020 10:20 am
it just says
adaradio test
or something like that
justforfun
by justforfun on Sat Aug 08, 2020 10:22 am
also I would like to know if there is an led on the transmitter because none turns on when powered up
justforfun
by mikeysklar on Mon Aug 10, 2020 5:56 pm
There are two LEDs on the FM Radio board which you can attempt to turn illuminate. This code should set them as outputs.
setGPIOctrl((1<<2) || (1<<1))
This line should turn them on.
https://learn.adafruit.com/adafruit-si4 ... -and-usage
GPIO Control
There's two GPIO pins you can use to blink LEDs. They are GPIO1 and GPIO2 - GPIO3 is used for the oscillator. To set them to be outputs call
setGPIOctrl(bitmask)
where the bitmask has a 1 bit for each of the two pins. For example to set GPIO2 to be an output use setGPIOctrl((1<<2)) to set both outputs, use setGPIOctrl((1<<2) || (1<<1))
Then you can set the output with
setGPIO(bitmask)
same idea with the bitmask, to turn both on, use setGPIOctrl((1<<2) || (1<<1)). To turn GPIO2 on and GPIO1 off, setGPIOctrl(1<<2)
mikeysklar
