Adafruit 2MB sound board not triggering sound
- Alfiejlee
I recently went to use my 2MB sound trigger board I plugged it into my computer and I heard a beep I then uploaded my sound file in the correct ogg format and then gave it the correct name (T02.OGG) relevant to the pin I wanted to use. I then soldered my wires on and connected the board to a 5v power bank the green light then came on however when I shorted my wire connected to pin 2 to the ground pin the red light did not come on and no sound was produced I’ve tried everything to different ways of powering it to different speakers , different wire , resoldering the wires onto the boards and trying different pins , I have also tried WAV files and changing the name of the files and my OGG sound file plays fine through my computer reading it off the adafruit board. Do you have any suggestions as to what I've done wrong.
Re: Adafruit 2MB sound board not triggering sound
Post a photo showing your hardware and connections and we'll take a look. 800x600 images usually work best.
- Alfiejlee
Here you go
- Attachments
- F145A30F-E215-4B11-B246-6EC583FD47A7.jpeg (37.33 KiB) Viewed 370 times
- compressjpeg.zip
- (716.8 KiB) Downloaded 5 times
- 18B12F93-0553-4020-938E-0F6B62A6B800.jpeg (1010.97 KiB) Viewed 370 times
Is the FX Board still connected to the computer through the USB cable?
The VS1000 won't play sounds while it still has a USB connection to the computer.
- Alfiejlee
No the sound board is not connected to the computer in this photo it was connected to a 5v power supply
Thank you. What voltages do you see on the trigger pins? Those can give us information about problems inside the chip.
- Alfiejlee
Is this the voltage between the trigger pins and the ground
- Alfiejlee
Here’s my results from testing the voltage from each pin
Pins 0-7 = 3.3v
Pin 8 = 1.2v
Pins 9-10 = 3.3v
Pins 0-7 = 3.3v
Pin 8 = 1.2v
Pins 9-10 = 3.3v
Bingo.. that's a hardware failure. Thank you.BANNED wrote:Pin 8 = 1.2v
Send a note containing a link to this page and your order number to [email protected]. The folks there will get you a replacement FX Board.
- Alfiejlee
Wow you’re a genius thank you so much
