Hi there! I'm having issues with the Adafruit light-up reactive ukulele project (https://learn.adafruit.com/light-up-reactive-ukulele). I just finished soldering it together, but am not seeing any of the Side Light Neopixel Strand light up, unfortunately. This uses the Feather Sense and Propmaker Featherwing.
The code.py I used is the exact one from the project with no modifications. My modifications from the original project are to use a straight M-F USB cable instead of one I soldered myself, and only using the single Side Light strand (and not adding on the light extension).
The lib file of my CIRCUITPY includes:
- adafruit_apds9960
- adafruit_bus_device
- adafruit_led_animation
- adafruit_lsm6ds
- adafruit_register
- adafruit_bmp280.mpy
- adafruit_lis3mdl.mpy
- adafruit_sht31d.mpy
- neopixel.mpy
The tutorial asks for adafruit_lsm6ds.mpy but I can't find that in the basic library to copy over.
Here's some photos of the board setup:
And video of the lights flashing:
https://streamable.com/jjp7tk
Let me know if you have any ideas - thanks in advance! Really excited to get this project moving. :)
Light-Up Reactive Ukulele Problems (Feather Sense)
- eeeeeepic
- mikeysklar
Re: Light-Up Reactive Ukulele Problems (Feather Sense)
Since you are only using one strip did you change the code in regards to the number NeoPixels? I believe the guides example utilizes 24 pixels per strip.
Soldering looks really good on the propmaker pins.
You are correct that there is no longer an adafruit_lsm6ds.mpy, but there is a folder in the CircuitPython library bundle titled:
adafruit_lsm6ds/
so you will want to copy the folder and it's contents to your lib folder.
Please make sure you libraries are in sync with the current CircuitPython release.
adafruit_lsm6ds/
- eeeeeepic
I didn't adjust the Neopixel count, which seems like a silly thing I should have considered! I'll give it a shot tomorrow and report back. :)mikeysklar wrote:Since you are only using one strip did you change the code in regards to the number NeoPixels? I believe the guides example utilizes 24 pixels per strip.
adafruit_lsm6ds/
Thanks for the compliment on the soldering! This was my first time soldering a row of pins onto a board like this (most of my experiments have been with Flora/Gem boards so far, which require a lot less precision) so I was pretty nervous, haha!
I did copy that library and the current Python release over; glad to see it confirmed that it was the right folder.
Thanks again for your help - I'll let you know how it goes!
- eeeeeepic
No luck just yet, unfortunately! I ran it through the mu editor but it mostly just seemed to find syntax errors to report. Anything you can see here that might be causing the issue? (I modified it to try and limit it to the 60 lights per strand.)
LED Ukulele with Feather Sense and PropMaker Wing
Adafruit invests time and resources providing this open source code.
Please support Adafruit and open source hardware by purchasing
products from Adafruit!
Written by Erin St Blaine & Limor Fried for Adafruit Industries
Copyright (c) 2019-2020 Adafruit Industries
Licensed under the MIT license.
All text above must be included in any redistribution.
MODES:
0 = off/powerup, 1 = sound reactive, 2 = non-sound reactive, 3 = tilt
Pluck high A on the E string to toggle sound reactive mode on or off
Pluck high A♭ on the E string to cycle through the animation modes
import time
import array
import digitalio
import audiobusio
import board
import neopixel
import ulab.numerical as numerical
import ulab.extras as extras
import ulab as np
import adafruit_lsm6ds
from adafruit_led_animation.helper import PixelMap
from adafruit_led_animation.sequence import AnimationSequence
from adafruit_led_animation.group import AnimationGroup
from adafruit_led_animation.animation.sparkle import Sparkle
from adafruit_led_animation.animation.rainbow import Rainbow
from adafruit_led_animation.animation.rainbowchase import RainbowChase
from adafruit_led_animation.animation.rainbowcomet import RainbowComet
from adafruit_led_animation.animation.chase import Chase
from adafruit_led_animation.animation.comet import Comet
from adafruit_led_animation.color import colorwheel
from adafruit_led_animation.color import (
BLACK,
RED,
ORANGE,
BLUE,
PURPLE,
WHITE,
MAX_BRIGHTNESS = 0.3 #set max brightness for sound reactive mode
NORMAL_BRIGHTNESS = 0.1 #set brightness for non-reactive mode
VOLUME_CALIBRATOR = 50 #multiplier for brightness mapping
ROCKSTAR_TILT_THRESHOLD = 200 #shake threshold
SOUND_THRESHOLD = 430000 #main strum or pluck threshold
# Set to the length in seconds for the animations
POWER_ON_DURATION = 1.3
ROCKSTAR_TILT_DURATION = 1
NUM_PIXELS = 60 # Number of pixels used in project
NEOPIXEL_PIN = board.D5
POWER_PIN = board.D10
enable = digitalio.DigitalInOut(POWER_PIN)
enable.direction = digitalio.Direction.OUTPUT
enable.value = False
i2c = board.I2C()
pixels = neopixel.NeoPixel(NEOPIXEL_PIN, NUM_PIXELS, brightness=1, auto_write=False)
pixels.fill(0) # NeoPixels off ASAP on startup
pixels.show()
#PIXEL MAPS: Used for reordering pixels so the animations can run in different configurations.
#My LED strips inside the neck are accidentally swapped left-right,
#so these maps also correct for that
#Bottom up along both sides at once
pixel_map_reverse = PixelMap(pixels, [
0, 60, 1, 59, 2, 58, 3, 57, 4, 56, 5, 55, 6, 54 7, 53, 8, 52, 9, 51, 10,
50, 11, 49, 12, 48, 13, 47, 14, 46, 15, 45, 16, 44, 17, 43, 18, 42, 19, 41, 20,
40, 21, 39, 22, 38, 23, 37, 24, 36, 25, 35, 26, 34, 27, 33, 28, 32, 29, 31, 30,
], individual_pixels=True)
#Starts at the bottom and goes around clockwise
pixel_map_around = PixelMap(pixels, [
0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20,
21, 22, 23, 24, 25, 26, 27, 60, 59, 58, 57, 56, 55, 54, 53, 52, 51, 50, 49,
48, 47, 46, 45, 44, 43, 42, 41, 40, 39, 38, 37, 36, 35, 34, 33, 32, 31, 30, 29, 28,
pixel_map_radiate = PixelMap(pixels, [
pixel_map_sweep = PixelMap(pixels, [
pixel_map_skip = PixelMap(pixels, [
pixel_map = [
pixel_map_reverse,
pixel_map_around,
pixel_map_radiate,
pixel_map_sweep,
pixel_map_skip,
#Set up accelerometer & mic
sensor = adafruit_lsm6ds.LSM6DS33(i2c)
mic = audiobusio.PDMIn(board.MICROPHONE_CLOCK,
board.MICROPHONE_DATA,
sample_rate=16000,
bit_depth=16)
NUM_SAMPLES = 256
samples_bit = array.array('H', [0] * (NUM_SAMPLES+3))
def power_on(duration):
Animate NeoPixels for power on.
start_time = time.monotonic() # Save start time
while True:
elapsed = time.monotonic() - start_time # Time spent
if elapsed > duration: # Past duration?
break # Stop animating
powerup.animate()
def rockstar_tilt(duration):
Tilt animation - lightning effect with a rotating color
:param duration: duration of the animation, in seconds (>0.0)
tilt_time = time.monotonic() # Save start time
while True:
elapsed = time.monotonic() - tilt_time # Time spent
pixels.brightness = MAX_BRIGHTNESS
pixels.fill(TILT_COLOR)
pixels.show()
time.sleep(0.01)
pixels.fill(BLACK)
pixels.show()
time.sleep(0.03)
pixels.fill(WHITE)
pixels.show()
time.sleep(0.02)
pixels.fill(BLACK)
pixels.show()
time.sleep(0.005)
pixels.show()
time.sleep(0.01)
pixels.fill(BLACK)
pixels.show()
time.sleep(0.03)
# Cusomize LED Animations ------------------------------------------------------
powerup = RainbowComet(pixel_map[3], speed=0, tail_length=15, bounce=False)
rainbow = Rainbow(pixel_map[4], speed=0, period=6, name="rainbow", step=2.4)
rainbow_chase = RainbowChase(pixel_map[3], speed=0, size=3, spacing=5, step=10)
rainbow_chase2 = RainbowChase(pixel_map[2], speed=0, size=10, spacing=1, step=8)
chase = Chase(pixel_map[1], speed=0.1, color=RED, size=1, spacing=6)
rainbow_comet = RainbowComet(pixel_map[2], speed=0, tail_length=20, bounce=True)
rainbow_comet2 = RainbowComet(
pixel_map[0], speed=0, tail_length=60, colorwheel_offset=80, bounce=True
rainbow_comet3 = RainbowComet(
pixel_map[1], speed=0, tail_length=15, colorwheel_offset=80, step=4, bounce=False
strum = RainbowComet(
pixel_map[3], speed=0, tail_length=15, bounce=False, colorwheel_offset=50, step=4
lava = Comet(pixel_map[3], speed=0.01, color=ORANGE, tail_length=20, bounce=False)
sparkle = Sparkle(pixel_map[4], speed=0.01, color=BLUE, num_sparkles=10)
sparkle2 = Sparkle(pixel_map[1], speed=0.05, color=PURPLE, num_sparkles=4)
# Animations Playlist - reorder as desired. AnimationGroups play at the same time
animations = AnimationSequence(
rainbow,
rainbow_chase,
rainbow_chase2,
chase,
lava,
rainbow_comet,
rainbow_comet2,
AnimationGroup(
sparkle,
strum,
AnimationGroup(
sparkle2,
rainbow_comet3,
auto_clear=True,
auto_reset=True,
MODE = 0
LASTMODE = 1 # start up in sound reactive mode
i = 0
# Main loop
while True:
i = (i + 0.5) % 256 # run from 0 to 255
TILT_COLOR = colorwheel(i)
if MODE == 0: # If currently off...
enable.value = True
power_on(POWER_ON_DURATION) # Power up!
MODE = LASTMODE
elif MODE >= 1: # If not OFF MODE...
mic.record(samples_bit, len(samples_bit))
samples = np.array(samples_bit[3:])
spectrum = extras.spectrogram(samples)
spectrum = spectrum[:128]
spectrum[0] = 0
spectrum[1] = 0
peak_idx = numerical.argmax(spectrum)
peak_freq = peak_idx * 16000 / 256
# print((peak_idx, peak_freq, spectrum[peak_idx]))
magnitude = spectrum[peak_idx]
# time.sleep(1)
if peak_freq == 812.50 and magnitude > SOUND_THRESHOLD:
animations.next()
time.sleep(1)
if peak_freq == 875 and magnitude > SOUND_THRESHOLD:
if MODE == 1:
MODE = 2
print("mode = 2")
LASTMODE = 2
time.sleep(1)
elif MODE == 2:
MODE = 1
print("mode = 1")
LASTMODE = 1
time.sleep(1)
# Read accelerometer
x, y, z = sensor.acceleration
accel_total = x * x + y * y # x=tilt, y=rotate
# print (accel_total)
if accel_total > ROCKSTAR_TILT_THRESHOLD:
MODE = 3
print("Tilted: ", accel_total)
if MODE == 1:
VOLUME = magnitude / (VOLUME_CALIBRATOR * 100000)
if VOLUME > MAX_BRIGHTNESS:
VOLUME = MAX_BRIGHTNESS
# print(VOLUME)
pixels.brightness = VOLUME
# time.sleep(2)
animations.animate()
elif MODE == 2:
pixels.brightness = NORMAL_BRIGHTNESS
elif MODE == 3:
rockstar_tilt(ROCKSTAR_TILT_DURATION)
MODE = LASTMODE
- eeeeeepic
Hi again,
So, I found one error - it turns out this is a 90 pixel strand, not a 60 one. I had ordered the 60, and my order history indicates that, but in the email it was switched to a 90 LED Side Strand? Not complaining, mind you! More lights are always great!
As such I've updated the code to the following, but am still getting a flashing error. The error is a long green, long yellow, break, short yellow x 2, short cyan x 4. Which indicates an error at Line 24... which is importing ulab.extras as extras. I cannot even guess what the problem might be there, and a Google hasn't helped either. The code seems to clear mu's check process without issue. Any suggestions?
MODES:
import time
import array
import digitalio
import audiobusio
import board
import neopixel
import ulab as np
BLACK,
RED,
ORANGE,
BLUE,
PURPLE,
WHITE,
MAX_BRIGHTNESS = 0.3 # set max brightness for sound reactive mode
NORMAL_BRIGHTNESS = 0.1 # set brightness for non-reactive mode
VOLUME_CALIBRATOR = 50 # multiplier for brightness mapping
ROCKSTAR_TILT_THRESHOLD = 200 # shake threshold
SOUND_THRESHOLD = 430000 # main strum or pluck threshold
NUM_PIXELS = 90 # Number of pixels used in project
i2c = board.I2C()
auto_write=False)
pixels.show()
# PIXEL MAPS: Used for reordering pixels so the animations can run
# in different configurations.
# My LED strips inside the neck are accidentally swapped left-right,
# so these maps also correct for that
# Bottom up along both sides at once
0, 90, 1, 89, 2, 88, 3, 87, 4, 86, 5, 85, 6, 84, 7, 83, 8, 82, 9, 81, 10,
80, 11, 79, 12, 78, 13, 77, 14, 76, 15, 75, 16, 74, 17, 73, 18, 72,
19, 71, 20, 70, 21, 69, 22, 68, 23, 67, 24, 66, 25, 65, 26, 64, 27,
63, 28, 62, 29, 61, 30, 60, 31, 59, 32, 58, 33, 57, 34, 56, 35, 55,
36, 54, 37, 53, 38, 52, 39, 51, 40, 49, 41, 48, 42, 47, 43, 46, 44,
45,
# Starts at the bottom and goes around clockwise
21, 22, 23, 24, 25, 26, 27, 75, 74, 73, 72, 71, 70, 69, 68, 67, 66, 65, 64,
63, 62, 61, 60, 59, 58, 57, 56, 55, 54, 53, 52, 51, 50, 49, 48, 47, 46, 45,
76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90,
# Radiates from the center outwards like a starburst
75, 73, 76, 27, 28, 74, 77, 26, 29, 73, 78, 25, 30, 72, 79, 24, 31, 71, 80,
23, 32, 70, 81, 22, 33, 69, 82, 21, 34, 68, 83, 20, 35, 67, 84, 19, 36, 66,
85, 18, 37, 65, 38, 86, 17, 64, 39, 87, 16, 63, 40, 88, 15, 62, 41, 89, 14,
61, 42, 90, 13, 60, 43, 12, 59, 44, 11, 58, 45, 10, 57, 46,
9, 56, 47, 8, 55, 48, 7, 54, 49, 6, 53, 50, 5, 52, 51,
4, 3, 2, 1, 0,
# Top down along both sides at once
51, 52, 50, 53, 49, 54, 48, 55, 47, 56, 46, 57, 45, 58, 44, 59, 43, 60,
42, 61, 41, 62, 40, 63, 39, 64, 38, 65, 37, 66, 36, 67, 35, 68, 34, 69,
33, 70, 32, 71, 31, 72, 30, 73, 29, 74, 28, 75, 27, 76, 27, 77, 26, 78,
25, 79, 24, 80, 23, 81, 22, 82, 21, 83, 20, 84, 19, 85, 18, 86, 17, 87,
16, 88, 15, 89, 14, 90,
# Every other pixel, starting at the bottom and going upwards along both sides
0, 90, 2, 88, 4, 86, 6, 84, 8, 82, 10, 80, 12, 78, 14, 76, 16, 74, 18, 72,
20, 70, 22, 68, 24, 66, 26, 64, 29, 62, 31, 60, 33, 58, 35, 56, 37, 54, 39,
52, 41, 50, 43, 48, 45, 46, 47,
pixel_map = [
pixel_map_reverse,
pixel_map_around,
pixel_map_radiate,
pixel_map_sweep,
pixel_map_skip,
# Set up accelerometer & mic
sample_rate=16000,
bit_depth=16)
NUM_SAMPLES = 256
while True:
powerup.animate()
while True:
pixels.show()
time.sleep(0.01)
pixels.fill(BLACK)
pixels.show()
time.sleep(0.03)
pixels.fill(WHITE)
pixels.show()
time.sleep(0.02)
pixels.fill(BLACK)
pixels.show()
time.sleep(0.005)
pixels.show()
time.sleep(0.01)
pixels.fill(BLACK)
pixels.show()
time.sleep(0.03)
powerup = RainbowComet(pixel_map[3], speed=0, tail_length=25, bounce=False)
rainbow_chase = RainbowChase(pixel_map[3], speed=0, size=3, spacing=15,
step=10)
step=18)
rainbow_comet = RainbowComet(pixel_map[2], speed=0, tail_length=45,
bounce=True)
pixel_map[0], speed=0, tail_length=50, colorwheel_offset=80, bounce=True
pixel_map[1], speed=0, tail_length=25, colorwheel_offset=80, step=4,
bounce=False
pixel_map[3], speed=0, tail_length=25, bounce=False, colorwheel_offset=50,
step=4
lava = Comet(pixel_map[3], speed=0.01, color=ORANGE, tail_length=40,
bounce=False)
# the same time
rainbow,
rainbow_chase,
rainbow_chase2,
chase,
lava,
rainbow_comet,
rainbow_comet2,
AnimationGroup(
sparkle,
strum,
AnimationGroup(
sparkle2,
rainbow_comet3,
auto_clear=True,
auto_reset=True,
MODE = 0
i = 0
# Main loop
while True:
enable.value = True
MODE = LASTMODE
spectrum[0] = 0
spectrum[1] = 0
# time.sleep(1)
animations.next()
time.sleep(1)
if MODE == 1:
MODE = 2
print("mode = 2")
LASTMODE = 2
time.sleep(1)
elif MODE == 2:
MODE = 1
print("mode = 1")
LASTMODE = 1
time.sleep(1)
MODE = 3
if MODE == 1:
# print(VOLUME)
# time.sleep(2)
elif MODE == 2:
elif MODE == 3:
MODE = LASTMODE
- eeeeeepic
One more update: I've tried testing the NeoPixels themselves with the following code:
No luck - none of the pixels on the strand are lighting up. There are no error codes flashing on the board - it's doing the rainbow pattern. I've also tried soldering my other connector onto the other end of the NeoPixel strand, and had no luck using that either.
Does it seem like there might be a flaw with the board or the light strand, maybe? Is there something I seem to noticeably be doing wrong, or should I just reorder the parts and see if that'll help? The solder links seem strong, so I don't think that's the flaw...
EDIT: SUCCESS! I got the lights to actually work with the following code:
This leaves the issue with the original ukulele code though - I'm still having issues at the ulab line. Anyone have any thoughts? (And thanks to anyone who has followed this neverending journey so far, haha.)
import time
import board
import neopixel
# On CircuitPlayground Express, and boards with built in status NeoPixel
# -> board.NEOPIXEL
# Otherwise choose an open pin connected to the Data In of the NeoPixel
# strip, i.e. board.D1
pixel_pin = board.NEOPIXEL
# On a Raspberry pi, use this instead, not all pins are supported
# pixel_pin = board.D18
# The number of NeoPixels
num_pixels = 90
# The order of the pixel colors - RGB or GRB. Some NeoPixels have red and
# green reversed!
# For RGBW NeoPixels, simply change the ORDER to RGBW or GRBW.
ORDER = neopixel.GRB
pixel_pin, num_pixels, brightness=0.2, auto_write=False,
pixel_order=ORDER
def wheel(pos):
# Input a value 0 to 255 to get a color value.
# The colours are a transition r - g - b - back to r.
if pos < 0 or pos > 255:
r = g = b = 0
elif pos < 85:
r = int(pos * 3)
g = int(255 - pos * 3)
b = 0
elif pos < 170:
pos -= 85
r = int(255 - pos * 3)
g = 0
b = int(pos * 3)
else:
pos -= 170
r = 0
g = int(pos * 3)
b = int(255 - pos * 3)
return (r, g, b) if ORDER in (neopixel.RGB, neopixel.GRB) else (r, g,
b, 0)
def rainbow_cycle(wait):
for j in range(255):
for i in range(num_pixels):
pixel_index = (i * 256 // num_pixels) + j
pixels[i] = wheel(pixel_index & 255)
pixels.show()
time.sleep(wait)
while True:
# Comment this line out if you have RGBW/GRBW NeoPixels
pixels.fill((255, 0, 0))
# Uncomment this line if you have RGBW/GRBW NeoPixels
# pixels.fill((255, 0, 0, 0))
pixels.show()
time.sleep(1)
pixels.fill((0, 255, 0))
# pixels.fill((0, 255, 0, 0))
pixels.show()
time.sleep(1)
pixels.fill((0, 0, 255))
# pixels.fill((0, 0, 255, 0))
pixels.show()
time.sleep(1)
rainbow_cycle(0.001) # rainbow cycle with 1ms delay per step
"""Simple rainbow example for 30-pixel NeoPixel strip"""
import digitalio
import board
import neopixel
NUM_PIXELS = 90 # NeoPixel strip length (in pixels)
enable = digitalio.DigitalInOut(board.D10)
enable.value = True
strip = neopixel.NeoPixel(board.D5, NUM_PIXELS, brightness=1)
def wheel(pos):
return (0, 0, 0)
if pos < 85:
return (255 - pos * 3, pos * 3, 0)
if pos < 170:
pos -= 85
return (0, 255 - pos * 3, pos * 3)
pos -= 170
return (pos * 3, 0, 255 - pos * 3)
while True:
for i in range(255):
strip.fill((wheel(i)))
- mikeysklar
Good job getting the NeoPixels going. It looks like they are working on the same pin (D5) as the Ukulele example. I assume you went back to the 'original' Ukulele code we supply and updated your NUM_PIXELS as the guide suggests?
It sounds like the conflict is elsewhere. I would start adding print statements and watch the REPL console to see which functions are getting called. The power_on() method has some timing logic which you will want to make sure you getting through to the powerup.animate() call.
- James1234
I am trying to do the same and I'm having exactly the same problem. Did you ever find a solution?eeeeeepic wrote:Which indicates an error at Line 24... which is importing ulab.extras as extras. I cannot even guess what the problem might be there, and a Google hasn't helped either. The code seems to clear mu's check process without issue. Any suggestions?
"ImportError: no module named 'ulab.extras'"
It seems to work without the error message with CircuitPython 5.3.1 (but the LEDs so far don't work), but not with 6 or 7 for which the guides seems to have been made. Maybe something else changed by now and this build-in library "ulab" doesn't exist any more or has been renamed? I also noticed that the libraries mentioned in the guide are not 100 identical to those put into the project file.
It's a bit of a shame that those guides are all half broken and are not being updated any longer. People who try to learn with those guides are then left to their own devices and cannot finish a project.
- mikeysklar
@James1234,
ulab is a built-in so I'm guessing what has changed from CP 5.x going to newer CP 6.x/7.x is how the core module has renamed the extensions. There is no more ulab.extras, but you should be able to use:
- ulab.numpy
- ulab.scipy
- ulab.user
- jepler1
Hi! I think I helped Erin with this code when the guide was first written.
ulab has been revised several times through various Python versions. There's currently a pull request open that is intended to make it compatible with CircuitPython 7.0.0-alpha.5. If you're able to test it out and give us feedback that would be great! You can find the Pull Request here: https://github.com/adafruit/Adafruit_Le ... /pull/1675
