It's Holiday Sale Weekend at Adafruit - use the code ADATY to get 15% off items storewide! Some restrictions apply.
Trying to flash HEX file to nRF52840 without Arduino IDE
by sminogue on Sun Oct 17, 2021 2:21 pm
Ive been poking at this for awhile. I am looking for a way to allow an end user to apply updates to an nRF52840 based device. I REALLY cannot expect my end user to install Arduino IDE and all the libraries, compile and upload my source.
I keep finding posts about this here and on the Arduino site about enabling verbose mode in the IDE and copying the command line. I tried...
MyMachine% /.../Arduino15/packages/adafruit/hardware/nrf52/1.1.0/tools/adafruit-nrfutil/macos/adafruit-nrfutil --verbose dfu serial -pkg /.../tc_firmware_v1.ino.zip -p /dev/cu.usbmodem1101 -b 115200 --singlebank
Upgrading target on /dev/cu.usbmodem1101 with DFU package /.../tc_firmware_v1.ino.zip. Flow control is disabled, Single bank, Touch disabled
Opened serial port /dev/cu.usbmodem1101
Starting DFU upgrade of type 4, SoftDevice size: 0, bootloader size: 0, application size: 165564
Sending DFU start packet
Timed out waiting for acknowledgement from device.
Failed to upgrade target. Error is: No data received on serial port. Not able to proceed.
  File "__main__.py", line 296, in serial
  ... StackTrace Follows
Even if this worked... Frankly my end users are not going to be up for breaking out powershell and putting in some command that looks like Klingon to them.
There HAS to be a better way of allowing non-technical end users to push updates to Adafruit devices in the wild...
Anyone know of how this is being accomplished? I keep coming up empty on my searches.
sminogue
Re: Trying to flash HEX file to nRF52840 without Arduino IDE
by mikeysklar on Tue Oct 19, 2021 8:49 pm
The Arduino IDE is probably the easiest of the options available for sending a HEX file of a sketch to a nRF52. Using arduino-cli or avrdude will just be more complicated.
It looks like yours is timing out from not being in DFU mode (connect DFU to GND).
https://learn.adafruit.com/bluefruit-nr ... bootloader
mikeysklar
