ADAFRUIT BLUEFRUIT FEATHER NRF52840: CANT FLASH BOOTLOADER
by matead on Tue Oct 26, 2021 12:35 am
Hi. I have an Adafruit Feather nRF52840, and I have tried to upload one of the examples but whenever I try to do so, I get this error
C:\Users\Matt\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\1.1.0/tools/adafruit-nrfutil/win32/adafruit-nrfutil.exe --verbose dfu serial -pkg C:\Users\Matt\AppData\Local\Temp\arduino_build_4974/central_scan.ino.zip -p COM8 -b 115200 --singlebank
Upgrading target on COM8 with DFU package C:\Users\Matt\AppData\Local\Temp\arduino_build_4974\central_scan.ino.zip. Flow control is disabled, Single bank, Touch disabled
Opened serial port COM8
Starting DFU upgrade of type 4, SoftDevice size: 0, bootloader size: 0, application size: 66292
Sending DFU start packet
Sending DFU init packet
Sending firmware file
Failed to upgrade target. Error is: WriteFile failed (PermissionError(13, 'The device does not recognize the command.', None, 22))
  File "__main__.py", line 296, in serial
  File "dfu\dfu.py", line 235, in dfu_send_images
  File "dfu\dfu.py", line 206, in _dfu_send_image
  File "dfu\dfu_transport_serial.py", line 213, in send_firmware
  File "dfu\dfu_transport_serial.py", line 241, in send_packet
  File "serial\serialwin32.py", line 317, in write
serial.serialutil.SerialException: WriteFile failed (PermissionError(13, 'The device does not recognize the command.', None, 22))
Possible causes:
- Selected Bootloader version does not match the one on Bluefruit device.
    Please upgrade the Bootloader or select correct version in Tools->Bootloader.
- Baud rate must be 115200, Flow control must be off.
- Target is not in DFU mode. Ground DFU pin and RESET and release both to enter DFU mode.
I then try to update the bootloader, but I get this error
C:\Users\Matt\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\1.1.0/bootloader/feather_nrf52832/feather_nrf52832_bootloader-0.6.2_s132_6.1.1.zip -p COM8 -b 115200 --touch 1200
Upgrading target on COM8 with DFU package C:\Users\Matt\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\1.1.0\bootloader\feather_nrf52832\feather_nrf52832_bootloader-0.6.2_s132_6.1.1.zip. Flow control is disabled, Dual bank, Touch 1200
Touched serial port COM8
Starting DFU upgrade of type 3, SoftDevice size: 147792, bootloader size: 21704, application size: 0
  File "dfu\dfu.py", line 226, in dfu_send_images
Possible causes:
What the hell is going on? I'm using Windows 10 (64-bit) with the latest Adafruit libraries that the Arduino IDE had listed.
Thanks.
matead
Re: ADAFRUIT BLUEFRUIT FEATHER NRF52840: CANT FLASH BOOTLOAD
by matead on Tue Oct 26, 2021 3:30 pm
Okay, after hours of troubleshooting, I managed to update the bootloader by using "feather_nrf52840_express_bootloader-0.6.2.zip" from your GitHub and using the ZIP within it with "adafruit-nrfutil.exe".
So that's updated now to
    UF2 Bootloader 0.6.2 lib/nrfx (v2.0.0) lib/tinyusb (0.10.1-293-gaf8e5a90) lib/uf2 (remotes/origin/configupdate-9-gadbb8c7)
    Model: Adafruit Feather nRF52840 Express
    Board-ID: nRF52840-Feather-revD
    SoftDevice: S140 version 6.1.1
    Date: Sep 10 2021
However, I still cannot upload the Arduino examples. I am getting this error.
C:\Users\Matt\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\1.1.0/tools/adafruit-nrfutil/win32/adafruit-nrfutil.exe --verbose dfu serial -pkg C:\Users\Matt\AppData\Local\Temp\arduino_build_314717/central_scan.ino.zip -p COM8 -b 115200 --singlebank
Upgrading target on COM8 with DFU package C:\Users\Matt\AppData\Local\Temp\arduino_build_314717\central_scan.ino.zip. Flow control is disabled, Single bank, Touch disabled
Failed to upgrade target. Error is: ClearCommError failed (PermissionError(13, 'The device does not recognize the command.', None, 22))
  File "dfu\dfu.py", line 203, in _dfu_send_image
  File "dfu\dfu_transport_serial.py", line 155, in send_init_packet
  File "dfu\dfu_transport_serial.py", line 243, in send_packet
  File "dfu\dfu_transport_serial.py", line 264, in get_ack_nr
  File "serial\serialwin32.py", line 275, in read
serial.serialutil.SerialException: ClearCommError failed (PermissionError(13, 'The device does not recognize the command.', None, 22))
Possible causes:
matead
by matead on Tue Oct 26, 2021 3:34 pm
Okay, I had the wrong board selected it seems from the Arduino menu. Seems to be working now. Hope this helps anyone else who runs into this problem.
matead
