DRV8833 DC/Stepper Motor Driver Breakout Board with Raspberr
by AAurion on Tue Oct 19, 2021 4:49 pm
I'm trying to run a DC motor off my Raspberry Pi Pico, so I got this motor driver off Adafruit. I'm trying to follow a bunch of tutorials, and eventually gave up trying to find documentation in C and went with Micropython. Right now, both motors I have will make a little buzzing/whining sound, but not turn. I'm not sure if this means they're not getting enough power, or if something is wired incorrectly.
I've included a power supply module on my board, which is plugged into a 5V 1A wall adaptor, so I thought I'd avoid having inadequate power...
This is the code that makes the whining noise:
import utime
from machine import Pin
motor1a = Pin(14, Pin.OUT)
motor1b = Pin(15, Pin.OUT)
def forward():
   motor1a.high()
   motor1b.low()
def backward():
   motor1a.low()
   motor1b.high()
def stop():
   motor1a.low()
   motor1b.low()
def test():
   forward()
   utime.sleep(2)
   backward()
   utime.sleep(2)
   stop()
for i in range(5):
    test()
I appreciate any help, thank you!
AAurion
Re: DRV8833 DC/Stepper Motor Driver Breakout Board with Rasp
by adafruit_support_bill on Tue Oct 19, 2021 7:26 pm
I don't see any common ground connection between the Pi and the DRV8833. All signals are measured relative to ground, so if there is no common ground, the behavior is unpredictable.
by AAurion on Tue Oct 19, 2021 8:30 pm
adafruit_support_bill wrote:I don't see any common ground connection between the Pi and the DRV8833. All signals are measured relative to ground, so if there is no common ground, the behavior is unpredictable.
Oh, I thought that since I was supplying power from the power supply, the DRV8833 should be connected to ground from that? Is that not how it would work?
AAurion
by adafruit_support_bill on Tue Oct 19, 2021 8:33 pm
Looks like you have two different power sources. There is no guarantee that their grounds are at the same potential. You need to have a solid ground connection between them to establish the reference voltage of your signals.
by AAurion on Wed Oct 27, 2021 4:17 pm
adafruit_support_bill wrote:Looks like you have two different power sources. There is no guarantee that their grounds are at the same potential. You need to have a solid ground connection between them to establish the reference voltage of your signals.
I connected a ground pin on the Pico to the breadboard, where there's a ground connection going to the power supply, but the motor still makes the same whining noise...
AAurion
by adafruit_support_bill on Thu Oct 28, 2021 5:11 am
What happens if you connect the AIN1 pin from the DRV8833 directly to 5v?
