Due to high demand expect some shipping delays at this time, orders may not ship for 3-4 business days.
Better understanding Qt Py SAMD21 Analog vs Digital pinouts
by swooby on Wed Nov 24, 2021 10:22 pm
I am looking at to better understand the datasheet for the ATSAMD21:
https://www.mouser.com/datasheet/2/268/ ... 580554.pdf
The Qt Py SAMD21 appears to use the ATSAMD21E18A-U model.
That 256KB model is hard [for me] to find, so I am using what I hope is only a 128KB difference model ATSAMD21E17D-AU.
I hope there is not a huge difference between the "A-U" and "D-AU".
I am trying to understand in the pinout image how the Qt Py SAMD21 uses different pins that are designated in the datasheet as green for analog and blue for digital.
From Page 24 of the datasheet:
ATSAMDExxA/B/D datasheet pinout
Screenshot 2021-11-24 175525.jpg (73.77 KiB) Viewed 498 times
For example, in this keypad demo (https://learn.adafruit.com/deluxe-4x4-n ... d?view=all) they are controlling the columns using Qt Py SAMD21 pins SCL, TX, RX, and SCK, with SDA sending the neopixel data.
qt py SAMD21 controlling 1x4 neokey rows and columns
Screenshot 2021-11-24 175508.jpg (74.88 KiB) Viewed 498 times
Those pins resolve to the SAMD21's respective pins of PA17, PA06, PA07, and PA11, with PA16 sending the neopixel data.
Qt Py PCB pins controlling neokey columns
Screenshot 2021-11-24 175956.jpg (163.74 KiB) Viewed 498 times
In the first image, PA06 and PA07 are Analog, and PA11 and PA17 are Digital, and PA16 sending the neopixel data is also Digital.
Is it OK to mix and match Analog and Digital pins like that for the columns?
Must the neopixel pin be Digital, or could is also be any of the Analog pins?
Or maybe I am reading the datasheet pinouts all wrong or having some other brain fart.
Any help in understanding how to use the Qt Py SAMD21 pinouts and/or SAMD21 in general would be greatly appreciated.
My project is in relation to this thread, viewtopic.php?f=19&t=184476#p899657, in an attempt to cleanup the trace routes for the keypad columns on a 1x4 or larger keypad.
Thanks, and Happy Thanksgiving! Gobble Gobble!
swooby
Re: Better understanding Qt Py SAMD21 Analog vs Digital pino
by swooby on Wed Nov 24, 2021 11:04 pm
Basically, in the project's (https://learn.adafruit.com/deluxe-4x4-n ... d?view=all) code [by John Park]:
Screenshot 2021-11-24 185852.jpg (37.77 KiB) Viewed 494 times
A0, A1, A2, A3, A6, and A7 all show up in the SAMD21 datasheet as Analog pins PA02, PA03, PA04, PA05, PA06, and PA07 respectively.
A8 (SCK?) and SCL show in the SAMD21 datasheet as Digital pins PA11 and PA17 respecively.
Screenshot 2021-11-24 190954.jpg (197.21 KiB) Viewed 493 times
XxX Snap Apart Keypad Wiring.png (903.92 KiB) Viewed 493 times
Does it really not matter in this use case if there is a mix of datasheet spec'ed Analog and Digital pins used for the rows and/or columns, or is there some magic that `Adafruit_Keypad` is doing to initialize those pins?
swooby
by swooby on Thu Nov 25, 2021 12:15 am
I see a bit more detail about the pinouts here that may answer my question(s):
https://learn.adafruit.com/adafruit-qt- ... -3073174-3
It looks like a lot of the pins can be dual Analog or Digital purposed.
And it looks like Adafruit_Keypad initializes the rows as digital:
https://github.com/adafruit/Adafruit_Ke ... d.cpp#L116
void Adafruit_Keypad::begin() {
  _keystates = (volatile byte *)malloc(_numRows * _numCols);
  memset((void *)_keystates, 0, _numRows * _numCols);
  for (int i = 0; i < _numCols; i++) {
    pinMode(_col[i], OUTPUT);
    digitalWrite(_col[i], HIGH);
  for (int i = 0; i < _numRows; i++) {
    pinMode(_row[i], INPUT_PULLUP);
swooby
by westfw on Thu Nov 25, 2021 11:43 pm
Any of the "analog" pins on a SAMD21 can be used as a digital pin instead (and perhaps other functions.)
See the "I/O Multiplexing and Considerations" section of the data sheet.
And/or this spreadsheet: https://docs.google.com/spreadsheets/d/ ... sp=sharing
(QT Py isn't on there, though.)
westfw
cron
