Propmaker Audio Problem - Light Saber Project
by Bakerdozer on Fri Jan 28, 2022 8:58 pm
I'm following the light saber tutorial. https://learn.adafruit.com/lightsaber-f ... g/overview
I have everything wired up, but the speaker is not working. When I push the button to turn on the power the speaker is quite, when I push the button again to turn off the power the speaker makes a click sound and nothing more.
Everything else is working find. The LEDs work correctly and the REPL is showing the actions that are being triggers from the accelerometer in the Propmaker.
Below is the code. Any ideas?
import time
import math
import gc
import digitalio
from digitalio import DigitalInOut, Direction, Pull
import audioio
import audiocore
import busio
import board
import neopixel
import adafruit_lis3dh
# CUSTOMIZE YOUR COLOR HERE:
# (red, green, blue) -- each 0 (off) to 255 (brightest)
COLOR = (255, 0, 0)  # red
# COLOR = (100, 0, 255)  # purple
# COLOR = (0, 100, 255) #cyan
# CUSTOMIZE SENSITIVITY HERE: smaller numbers = more sensitive to motion
HIT_THRESHOLD = 1000 # 350
SWING_THRESHOLD = 500  #125
NUM_PIXELS = 28
# NUM_PIXELS = 114
# NUM_PIXELS = 85
NEOPIXEL_PIN = board.D5
POWER_PIN = board.D10
SWITCH_PIN = board.D9
enable = digitalio.DigitalInOut(POWER_PIN)
enable.direction = digitalio.Direction.OUTPUT
enable.value = False
red_led = DigitalInOut(board.D11)
red_led.direction = Direction.OUTPUT
green_led = DigitalInOut(board.D12)
green_led.direction = Direction.OUTPUT
blue_led = DigitalInOut(board.D13)
blue_led.direction = Direction.OUTPUT
audio = audioio.AudioOut(board.A0)     # Speaker
mode = 0                               # Initial mode = OFF
strip = neopixel.NeoPixel(NEOPIXEL_PIN, NUM_PIXELS, brightness=1, auto_write=False)
strip.fill(0)                          # NeoPixels off ASAP on startup
strip.show()
switch = DigitalInOut(SWITCH_PIN)
switch.direction = Direction.INPUT
switch.pull = Pull.UP
time.sleep(0.1)
# Set up accelerometer on I2C bus, 4G range:
i2c = busio.I2C(board.SCL, board.SDA)
accel = adafruit_lis3dh.LIS3DH_I2C(i2c)
accel.range = adafruit_lis3dh.RANGE_4_G
# "Idle" color is 1/4 brightness, "swinging" color is full brightness...
COLOR_IDLE = (int(COLOR[0] / 1), int(COLOR[1] / 1), int(COLOR[2] / 1))
COLOR_SWING = COLOR
COLOR_HIT = (255, 255, 255)  # "hit" color is white
def play_wav(name, loop=False):
    Play a WAV file in the 'sounds' directory.
    @param name: partial file name string, complete name will be built around
                 this, e.g. passing 'foo' will play file 'sounds/foo.wav'.
    @param loop: if True, sound will repeat indefinitely (until interrupted
                 by another sound).
    print("playing", name)
    try:
        wave_file = open('sounds/' + name + '.wav', 'rb')
        wave = audiocore.WaveFile(wave_file)
        audio.play(wave, loop=loop)
    except:
        return
def power(sound, duration, reverse):
    Animate NeoPixels with accompanying sound effect for power on / off.
    @param sound:    sound name (similar format to play_wav() above)
    @param duration: estimated duration of sound, in seconds (>0.0)
    @param reverse:  if True, do power-off effect (reverses animation)
    if reverse:
        prev = NUM_PIXELS
    else:
        prev = 0
    gc.collect()                   # Tidy up RAM now so animation's smoother
    start_time = time.monotonic()  # Save audio start time
    play_wav(sound)
    while True:
        elapsed = time.monotonic() - start_time  # Time spent playing sound
        if elapsed > duration:                   # Past sound duration?
            break                                # Stop animating
        fraction = elapsed / duration            # Animation time, 0.0 to 1.0
        if reverse:
            fraction = 1.0 - fraction            # 1.0 to 0.0 if reverse
        fraction = math.pow(fraction, 0.5)       # Apply nonlinear curve
        threshold = int(NUM_PIXELS * fraction + 0.5)
        num = threshold - prev # Number of pixels to light on this pass
        if num != 0:
            if reverse:
                strip[threshold:prev] = [0] * -num
            else:
                strip[prev:threshold] = [COLOR_IDLE] * num
            strip.show()
            # NeoPixel writes throw off time.monotonic() ever so slightly
            # because interrupts are disabled during the transfer.
            # We can compensate somewhat by adjusting the start time
            # back by 30 microseconds per pixel.
            start_time -= NUM_PIXELS * 0.00003
            prev = threshold
    if reverse:
        strip.fill(0)                            # At end, ensure strip is off
    else:
        strip.fill(COLOR_IDLE)                   # or all pixels set on
    strip.show()
    while audio.playing:                         # Wait until audio done
        pass
def mix(color_1, color_2, weight_2):
    Blend between two colors with a given ratio.
    @param color_1:  first color, as an (r,g,b) tuple
    @param color_2:  second color, as an (r,g,b) tuple
    @param weight_2: Blend weight (ratio) of second color, 0.0 to 1.0
    @return: (r,g,b) tuple, blended color
    if weight_2 < 0.0:
        weight_2 = 0.0
    elif weight_2 > 1.0:
        weight_2 = 1.0
    weight_1 = 1.0 - weight_2
    return (int(color_1[0] * weight_1 + color_2[0] * weight_2),
            int(color_1[1] * weight_1 + color_2[1] * weight_2),
            int(color_1[2] * weight_1 + color_2[2] * weight_2))
# Main program loop, repeats indefinitely
while True:
    red_led.value = True
    if not switch.value:                    # button pressed?
        if mode == 0:                       # If currently off...
            enable.value = True
            power('on', 1.7, False)         # Power up!
            play_wav('idle', loop=True)     # Play background hum sound
            mode = 1                        # ON (idle) mode now
        else:                               # else is currently on...
            power('off', 1.15, True)        # Power down
            mode = 0                        # OFF mode now
        while not switch.value:             # Wait for button release
            time.sleep(0.2)                 # to avoid repeated triggering
    elif mode >= 1:                         # If not OFF mode...
        x, y, z = accel.acceleration # Read accelerometer
        accel_total = x * x + z * z
        # (Y axis isn't needed for this, assuming Hallowing is mounted
        # sideways to stick.  Also, square root isn't needed, since we're
        # just comparing thresholds...use squared values instead, save math.)
        if accel_total > HIT_THRESHOLD:   # Large acceleration = HIT
            TRIGGER_TIME = time.monotonic() # Save initial time of hit
            play_wav('hit')                 # Start playing 'hit' sound
            COLOR_ACTIVE = COLOR_HIT        # Set color to fade from
            mode = 3                        # HIT mode
        elif mode == 1 and accel_total > SWING_THRESHOLD: # Mild = SWING
            TRIGGER_TIME = time.monotonic() # Save initial time of swing
            play_wav('swing')               # Start playing 'swing' sound
            COLOR_ACTIVE = COLOR_SWING      # Set color to fade from
            mode = 2                        # SWING mode
        elif mode > 1:                      # If in SWING or HIT mode...
            if audio.playing:               # And sound currently playing...
                blend = time.monotonic() - TRIGGER_TIME # Time since triggered
                if mode == 2:               # If SWING,
                    blend = abs(0.5 - blend) * 2.0 # ramp up, down
                strip.fill(mix(COLOR_ACTIVE, COLOR_IDLE, blend))
                strip.show()
            else:                           # No sound now, but still MODE > 1
                play_wav('idle', loop=True) # Resume background hum
                strip.fill(COLOR_IDLE)      # Set to idle color
                strip.show()
                mode = 1                    # IDLE mode now
Bakerdozer
Re: Propmaker Audio Problem - Light Saber Project
by Bakerdozer on Sat Jan 29, 2022 11:26 am
After doing some troubleshooting it appears to be a Propmaker board issue. I confirmed the Feather M4 board audio out is working correctly by following this tutorial. (https://learn.adafruit.com/circuitpytho ... -audio-out)
Anyone else have audio issues with the Propmaker?
Bakerdozer
by adafruit_support_mike on Sat Jan 29, 2022 4:02 pm
Post a photo showing your hardware and connections and we'll take a look. 800x600 images usually work best.
