I connected the board using the pins: SCA with pin 21 from esp32, SCL with pin 22, GND with GND, VCC with my 3.3v power pin) but I'm unable to find the chip.
When I compile the following example using plafatorm IO, it returns an erro code 2 from all address.
link with photos https://imgur.com/gallery/0Aebu6m
#include <Arduino.h>
#include <Wire.h>
Wire.begin(21, 22, (uint32_t) 400000);
Serial.begin(115200);
Serial.println("\nI2C Scanner");
byte error, address;
int nDevices = 0;
Serial.println("Scanning...");
for(address = 1; address < 127; address++ ) {
Wire.beginTransmission(address);
error = Wire.endTransmission();
Serial.printf("ADDRESS=%d -- ERROR=%d\n", address, error);
if (error == 0) {
Serial.print("I2C device found at address 0x");
if (address<16) {
Serial.print("0");
Serial.print(address,HEX);
Serial.println(" !");
nDevices++;
} else if (error==4) {
Serial.print("Unknown error at address 0x");
if (address<16) {
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0) {
Serial.println("No I2C devices found\n");
delay(5000);
