Teensy 4.1 Dead on Arrival
by a_sabater on Sat Jun 25, 2022 7:59 pm
I have a Teensy 4.1 (https://www.adafruit.com/product/4622) that I ordered on 6/17/2022 and arrived 6/24/2022 that I am pretty sure is dead on arrival. Got another Teensy on Adafruit to match the one I ordered from PJRC. I didn't test the device before soldering headers on it, but in the past, it would start a blink program once power was applied. The lights don't blink and I can't find an associated port when it's plugged in. I am pretty sure the device is defective.
Would it be possible to get a replacement? Please let me know if you need any more information.
Thank you!
a_sabater
Re: Teensy 4.1 Dead on Arrival
by adafruit_support_mike on Mon Jun 27, 2022 9:54 pm
As a sanity check, verify your USB cable by using it to connect some other, known-working device to a computer.
There's a plague of charge-only cables out there with USB connectors at both ends, but no wires for the data signals. People get caught by them every day.
Just swapping cables has no diagnostic value. The current record is someone who had to try ten cables before finding one that worked. Only a working USB connection can rule out a charge-only cable.
by a_sabater on Tue Jun 28, 2022 11:27 pm
Hi Mike!
Thanks for the reply and suggestions! I am pretty sure that it's not the cable. Attached are two pictures. The Teensy on the left is one I borrowed from a friend. I'm able to program it with the USB cable I have been using for a while and run a blink program (see the light). The Teensy on the right is the one that I ordered on 6/17. I'm not able to program that one and the lights don't turn on.
LED on.jpg (544.78 KiB) Viewed 142 times
LED off.jpg (672.65 KiB) Viewed 142 times
a_sabater
by adafruit_support_mike on Wed Jun 29, 2022 8:37 pm
That's a good comparison test.
What voltages do you see on the unresponsive board's 3V and 5V pins?
by a_sabater on Thu Jun 30, 2022 1:39 pm
Hi Mike,
Sorry for the delay. I wanted to borrow my friend's Teensy so I have a reference.
On my friend's Teensy, on the 5V and 3V pins, I measure 5.1V and 3.3V, respectively.
On my unresponsive Teensy, on the 5V and 3V pins, I measure 5.0V and 0.2V, respectively.
a_sabater
by adafruit_support_mike on Thu Jun 30, 2022 7:02 pm
Thank you. That means there's probably a short in the microcontroller.
Send a note containing a link to this page and your order number to support@adafruit.com. The folks there will get you a replacement.
by a_sabater on Thu Jun 30, 2022 7:17 pm
Thanks for the support Mike!
a_sabater
