Audio Adapter Board for Teensy speaker problem
- adamb2
Im currently using Teensy 3.2 and the audio adapter. The adapter works fine with any set of headphones, but when I try to use the 8ohm speaker https://www.adafruit.com/products/1890 it comes out incredibly faint. Does the audio adapter just not put out enough power for the speaker or might I be connecting it in the wrong spots? I would prefer not to have to use an amplifier as space is already a limiting factor.
- adafruit_support_rick
Re: Audio Adapter Board for Teensy speaker problem
That adapter doesn't have an amplifier. You need an amplifier to use it with a speaker.
