Has anyone had luck with getting I2C working between RPi and a Microchip PIC, in my case '18F2525'? I am using wiringPi compiler on RPi and Mikroelektronika compiler for the PIC. I am able to see the address of my PIC when I run 'i2cdetect -y 1', which is "34", see below, but I have not had any luck with sending or receiving any data across. I am also using the QuicktoWire board, which is showing up as address "20" below. Between RPI and the PIC I am using the "Bi-directional Logic Level Converter ". I have attached both codes for your information. Please let me know if anyone has any ideas or improvement to get this working.
# i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- UU -- -- -- --
20: 20 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- 34 -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
PIC-18F2525 Interface to RPi on I2C
- Giv
- wiringPi-write-to-PIC.c
- (2.08 KiB) Downloaded 161 times
- PIC18F2525-Slave.c.txt
- (5.32 KiB) Downloaded 160 times
Re: PIC-18F2525 Interface to RPi on I2C
I'm afraid we have more experience with the Atmel family of microcontrollers than PICs (though we'll see how the product families change now that Microchip has bought Atmel).
Maybe someone from the community will have experience using PICs as I2C slaves.
- zener
It seems like you are trying to test 3 things at once, two pieces of code and all the hardware including the level shifter. Do you have a scope so that you can at least verify the logic levels and clock speeds are correct? Do you have a known good device for either end to try to narrow down where the problem might be? In the mean time you might post on a Microchip forum and see if there is any help from that end. Good luck.
- Giv
Hi zener,
Thank you for your input.
Thanks again.
Givi
The wiringPi software has three functions, but I commented out two each time I ran it and test with them.zener wrote:It seems like you are trying to test 3 things at once,
I see the data on SCL and SDA lines and on both end everything is setup for 100K. Do you have any other software or compiler that I can use on the RPi to work with I2C?zener wrote: Do you have a scope so that you can at least verify the logic levels and clock speeds are correct?
Believe me I have posted this on a few site. There has to be a way and I2C is I2C. Any device that supports that protocol should be able to communicate with it to any other device, which supports I2C or something fundamentally is wrong.zener wrote: you might post on a Microchip forum and see if there is any help from that end.
Thanks again.
Givi
