motor shield address
- deanharvey
I soldered a jumper across A4, leftmost bridge, on the motor shield. Is 0x76 the correct address? The motor isn't responding.
Re: motor shield address
2^4 is 0x10 plus the base address of 0x60 = 0x70.
https://learn.adafruit.com/adafruit-mot ... he-shields
- deanharvey
isn't that the "all call" address of the motor shield? I'm using two motor shields, the first uses the default address.adafruit_support_bill wrote:2^4 is 0x10 plus the base address of 0x60 = 0x70.
Yes. 0x70 is the all-call address for the pca9685, so you should select a different. one.
You can use the i2c scanner to verify what address the board is responding to: http://playground.arduino.cc/Main/I2cScanner
