Hi, first of all I'm a newby to the teensy, and pretty much to a lot of this stuff. I'm a 70 yr. old tinkerer and build things that I gleen from web sites like this, and here's the problem.
I can't program the board!!
i'm trying to build the "animated eyes project" using the "3.2 teensy" board.
I'm using Arduino 1.6.5 r5 IDE. The instructions say this should work for this project.
OK.....long story short having followed everything in the instructions and all I get is the regular arduino screen and this message;
Arduino: 1.6.5 (Windows 8.1), TD: 1.36, Board: "Teensy 3.2 / 3.1, Serial, 72 MHz optimize speed, US English"
Cannot run program "C:\Program Files (x86)\Arduino\hardware\tools\arm\bin\arm-none-eabi-ar" (in directory "."): CreateProcess error=2, The system cannot find the file specified
enabled in File > Preferences.
can't blink a teeny 3.2 with arduino 1.6.5 ide
- rondog47
- Franklin97355
Re: can't blink a teeny 3.2 with arduino 1.6.5 ide
Try updating your IDE to the latest (1.8.3)
- rondog47
thanks for your reply.
I'll try that but will it transfer over all my current data to the new IDE ?
I say this because I did this before; coming from an old version to the now 1.6.5 version and I lost some boards data like attiny boards and had to locate and reload them, as an example.
I've heard of running two versions using different names.....whats your advise?
I'm always leery about software updates.
- Franklin97355
I do that.I've heard of running two versions using different names.....whats your advise?
- rondog47
just to bring you up to date; I'm trying to build a project called "uncanny eyes" posted on your web site
I just upgraded to ide 1.8.1 and got the "blink" to work on the "teensy" board.
now when I upload the program it doesn't recognize the board. here's the error message:
Arduino: 1.8.1 (Windows 10), TD: 1.36, Board: "Teensy 3.2 / 3.1, Serial, 72 MHz, Faster, US English"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\ronald\AppData\Local\Arduino15\packages -hardware C:\Users\ronald\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\ronald\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\ronald\Documents\Arduino\libraries -fqbn=teensy:avr:teensy31:usb=serial,speed=72,opt=o2std,keys=en-us -ide-version=10801 -build-path C:\Users\ronald\AppData\Local\Temp\arduino_build_581601 -warnings=none -verbose C:\Users\ronald\AppData\Local\Temp\Temp1_Teensy3.1_Eyes-master.zip\Teensy3.1_Eyes-master\uncannyEyes\uncannyEyes.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\ronald\AppData\Local\Arduino15\packages -hardware C:\Users\ronald\Documents\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\ronald\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\ronald\Documents\Arduino\libraries -fqbn=teensy:avr:teensy31:usb=serial,speed=72,opt=o2std,keys=en-us -ide-version=10801 -build-path C:\Users\ronald\AppData\Local\Temp\arduino_build_581601 -warnings=none -verbose C:\Users\ronald\AppData\Local\Temp\Temp1_Teensy3.1_Eyes-master.zip\Teensy3.1_Eyes-master\uncannyEyes\uncannyEyes.ino
Using board 'teensy31' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Using core 'teensy3' from platform in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=136 -DARDUINO=10801 -DF_CPU=72000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "C:\Users\ronald\AppData\Local\Temp\arduino_build_581601\sketch\uncannyEyes.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=136 -DARDUINO=10801 -DF_CPU=72000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI" "C:\Users\ronald\AppData\Local\Temp\arduino_build_581601\sketch\uncannyEyes.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=136 -DARDUINO=10801 -DF_CPU=72000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\ronald\Documents\Arduino\libraries\Adafruit_GFX" "C:\Users\ronald\AppData\Local\Temp\arduino_build_581601\sketch\uncannyEyes.ino.cpp" -o "nul"
"C:\Program Files (x86)\Arduino\hardware\teensy/../tools/arm/bin/arm-none-eabi-g++" -E -CC -x c++ -w -g -Wall -ffunction-sections -fdata-sections -nostdlib -fno-exceptions -felide-constructors -std=gnu++0x -fno-rtti -mthumb -mcpu=cortex-m4 -fsingle-precision-constant -D__MK20DX256__ -DTEENSYDUINO=136 -DARDUINO=10801 -DF_CPU=72000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\cores\teensy3" "-IC:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI" "-IC:\Users\ronald\Documents\Arduino\libraries\Adafruit_GFX" "C:\Users\ronald\AppData\Local\Temp\arduino_build_581601\sketch\uncannyEyes.ino.cpp" -o "C:\Users\ronald\AppData\Local\Temp\arduino_build_581601\preproc\ctags_target_for_gcc_minus_e.cpp"
C:\Users\ronald\AppData\Local\Temp\Temp1_Teensy3.1_Eyes-master.zip\Teensy3.1_Eyes-master\uncannyEyes\uncannyEyes.ino:19:63: fatal error: defaultEye.h: No such file or directory
compilation terminated.
Multiple libraries were found for "Adafruit_GFX.h"
Used: C:\Users\ronald\Documents\Arduino\libraries\Adafruit_GFX
Not used: C:\Users\ronald\Documents\Arduino\libraries\OLED_I2C
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI
Using library Adafruit_GFX in folder: C:\Users\ronald\Documents\Arduino\libraries\Adafruit_GFX (legacy)
Error compiling for board Teensy 3.2 / 3.1.
Please help or refer me,
thanks again.
thanks again.
- Franklin97355
When you check this library is the file there?
