Feather M0 connected to OneWire Device
by Johannesdewet on Sun Jul 23, 2017 5:16 pm
Hi there!
I have a Feather M0 connected to a Temp sensor (DS18B20), but for some reason I am receiving compile errors when including the OneWire (or DallasTemperature) libraries in my script. The same script compiled perfectly when selecting another board, like the Uno. The problem seems to be specific to the Feather M0 and those two Libraries. I've been able to compile and run a host of other scripts for the Feather (as long as they don't include OneWire)
Error code (there are other errors in the compile as well, but this is the first):
Documents\Arduino\libraries\MAX31850_OneWire/OneWire.h:108:2: error: #error "Please define I/O register types here"
Any ideas perhaps why I wont be able to compile a script for Feather M0? when OneWIre libraries are included?
Thanks in advance!
Johannesdewet
Re: Feather M0 connected to OneWire Device
by adafruit_support_mike on Mon Jul 24, 2017 11:24 pm
My first guess is that the code is written using registers that only exist in ATmega microcontrollers. A lot of older code that big-bangs an IO protocol does, since that allows better timing control than using .digitalWrite() to toggle pins high and low.
by Johannesdewet on Tue Jul 25, 2017 8:09 am
Thank you Mike!
Johannesdewet
by BryonMiller on Tue Jul 25, 2017 8:32 am
I have successfully used onewire devices with my Feather M0. Instead of the MAX31850_OneWire Library you are using I used one from https://www.pjrc.com/teensy/arduino_libraries/OneWire.zip
But then I replaced the OneWire.h file with the following
#ifndef OneWire_h
#define OneWire_h
#include <inttypes.h>
#if ARDUINO >= 100
#include "Arduino.h"       // for delayMicroseconds, digitalPinToBitMask, etc
#else
#include "WProgram.h"      // for delayMicroseconds
#include "pins_arduino.h"  // for digitalPinToBitMask, etc
#endif
// You can exclude certain features from OneWire.  In theory, this
// might save some space.  In practice, the compiler automatically
// removes unused code (technically, the linker, using -fdata-sections
// and -ffunction-sections when compiling, and Wl,--gc-sections
// when linking), so most of these will not result in any code size
// reduction.  Well, unless you try to use the missing features
// and redesign your program to not need them!  ONEWIRE_CRC8_TABLE
// is the exception, because it selects a fast but large algorithm
// or a small but slow algorithm.
// you can exclude onewire_search by defining that to 0
#ifndef ONEWIRE_SEARCH
#define ONEWIRE_SEARCH 1
#endif
// You can exclude CRC checks altogether by defining this to 0
#ifndef ONEWIRE_CRC
#define ONEWIRE_CRC 1
#endif
// Select the table-lookup method of computing the 8-bit CRC
// by setting this to 1.  The lookup table enlarges code size by
// about 250 bytes.  It does NOT consume RAM (but did in very
// old versions of OneWire).  If you disable this, a slower
// but very compact algorithm is used.
#ifndef ONEWIRE_CRC8_TABLE
#define ONEWIRE_CRC8_TABLE 1
#endif
// You can allow 16-bit CRC checks by defining this to 1
// (Note that ONEWIRE_CRC must also be 1.)
#ifndef ONEWIRE_CRC16
#define ONEWIRE_CRC16 1
#endif
#define FALSE 0
#define TRUE  1
// Platform specific I/O definitions
#if defined(__AVR__)
#define PIN_TO_BASEREG(pin)             (portInputRegister(digitalPinToPort(pin)))
#define PIN_TO_BITMASK(pin)             (digitalPinToBitMask(pin))
#define IO_REG_TYPE uint8_t
#define IO_REG_ASM asm("r30")
#define DIRECT_READ(base, mask)         (((*(base)) & (mask)) ? 1 : 0)
#define DIRECT_MODE_INPUT(base, mask)   ((*((base)+1)) &= ~(mask))
#define DIRECT_MODE_OUTPUT(base, mask)  ((*((base)+1)) |= (mask))
#define DIRECT_WRITE_LOW(base, mask)    ((*((base)+2)) &= ~(mask))
#define DIRECT_WRITE_HIGH(base, mask)   ((*((base)+2)) |= (mask))
#elif defined(__MK20DX128__)
#define PIN_TO_BASEREG(pin)             (portOutputRegister(pin))
#define PIN_TO_BITMASK(pin)             (1)
#define IO_REG_ASM
#define DIRECT_READ(base, mask)         (*((base)+512))
#define DIRECT_MODE_INPUT(base, mask)   (*((base)+640) = 0)
#define DIRECT_MODE_OUTPUT(base, mask)  (*((base)+640) = 1)
#define DIRECT_WRITE_LOW(base, mask)    (*((base)+256) = 1)
#define DIRECT_WRITE_HIGH(base, mask)   (*((base)+128) = 1)
// #elif defined(__SAM3X8E__)
#elif defined(__SAM3X8E__) || defined(__SAM3A8C__) || defined(__SAM3A4C__)
// Arduino 1.5.1 may have a bug in delayMicroseconds() on Arduino Due.
// http://arduino.cc/forum/index.php/topic,141030.msg1076268.html#msg1076268
// If you have trouble with OneWire on Arduino Due, please check the
// status of delayMicroseconds() before reporting a bug in OneWire!
#define PIN_TO_BASEREG(pin)             (&(digitalPinToPort(pin)->PIO_PER))
#define IO_REG_TYPE uint32_t
#define IO_REG_ASM
#define DIRECT_READ(base, mask)         (((*((base)+15)) & (mask)) ? 1 : 0)
#define DIRECT_MODE_INPUT(base, mask)   ((*((base)+5)) = (mask))
#define DIRECT_MODE_OUTPUT(base, mask)  ((*((base)+4)) = (mask))
#define DIRECT_WRITE_LOW(base, mask)    ((*((base)+13)) = (mask))
#define DIRECT_WRITE_HIGH(base, mask)   ((*((base)+12)) = (mask))
#ifndef PROGMEM
#define PROGMEM
#endif
#ifndef pgm_read_byte
#define pgm_read_byte(addr) (*(const uint8_t *)(addr))
#endif
#elif defined(__PIC32MX__)
#define PIN_TO_BASEREG(pin)             (portModeRegister(digitalPinToPort(pin)))
#define IO_REG_ASM
#define DIRECT_READ(base, mask)         (((*(base+4)) & (mask)) ? 1 : 0)  //PORTX + 0x10
#define DIRECT_MODE_INPUT(base, mask)   ((*(base+2)) = (mask))            //TRISXSET + 0x08
#define DIRECT_MODE_OUTPUT(base, mask)  ((*(base+1)) = (mask))            //TRISXCLR + 0x04
#define DIRECT_WRITE_LOW(base, mask)    ((*(base+8+1)) = (mask))          //LATXCLR  + 0x24
#define DIRECT_WRITE_HIGH(base, mask)   ((*(base+8+2)) = (mask))          //LATXSET + 0x28
#elif defined(ARDUINO_ARCH_ESP8266)
#warning "OneWire. Fallback mode. ARDUINO_ARCH_ESP8266"
    IO_REG_TYPE bitmask;
#elif defined(__SAMD21G18A__)
#define PIN_TO_BASEREG(pin)             portModeRegister(digitalPinToPort(pin))
#define IO_REG_ASM
#define DIRECT_READ(base, mask)         (((*((base)+8)) & (mask)) ? 1 : 0)
#define DIRECT_MODE_INPUT(base, mask)   ((*((base)+1)) = (mask))
#define DIRECT_MODE_OUTPUT(base, mask)  ((*((base)+2)) = (mask))
#define DIRECT_WRITE_LOW(base, mask)    ((*((base)+5)) = (mask))
#define DIRECT_WRITE_HIGH(base, mask)   ((*((base)+6)) = (mask))
#elif defined(RBL_NRF51822)
#define PIN_TO_BASEREG(pin)             (0)
#define PIN_TO_BITMASK(pin)             (pin)
#define IO_REG_ASM
#define DIRECT_READ(base, pin)          nrf_gpio_pin_read(pin)
#define DIRECT_WRITE_LOW(base, pin)     nrf_gpio_pin_clear(pin)
#define DIRECT_WRITE_HIGH(base, pin)    nrf_gpio_pin_set(pin)
#define DIRECT_MODE_INPUT(base, pin)    nrf_gpio_cfg_input(pin, NRF_GPIO_PIN_NOPULL)
#define DIRECT_MODE_OUTPUT(base, pin)   nrf_gpio_cfg_output(pin)
#warning "OneWire. Fallback mode. RBL_NRF51822"
#elif defined(__arc__) /* Arduino101/Genuino101 specifics */
#warning "OneWire. Fallback mode. __arc__"
#else
#endif
class OneWire
  private:
    volatile IO_REG_TYPE *baseReg;
#if ONEWIRE_SEARCH
    // global search state
    unsigned char ROM_NO[8];
    uint8_t LastDiscrepancy;
    uint8_t LastFamilyDiscrepancy;
    uint8_t LastDeviceFlag;
#endif
  public:
    OneWire( uint8_t pin);
    // Perform a 1-Wire reset cycle. Returns 1 if a device responds
    // with a presence pulse.  Returns 0 if there is no device or the
    // bus is shorted or otherwise held low for more than 250uS
    uint8_t reset(void);
    // Issue a 1-Wire rom select command, you do the reset first.
    void select(const uint8_t rom[8]);
    // Issue a 1-Wire rom skip command, to address all on bus.
    void skip(void);
    // Write a byte. If 'power' is one then the wire is held high at
    // the end for parasitically powered devices. You are responsible
    // for eventually depowering it by calling depower() or doing
    // another read or write.
    void write(uint8_t v, uint8_t power = 0);
    void write_bytes(const uint8_t *buf, uint16_t count, bool power = 0);
    // Read a byte.
    uint8_t read(void);
    void read_bytes(uint8_t *buf, uint16_t count);
    // Write a bit. The bus is always left powered at the end, see
    // note in write() about that.
    void write_bit(uint8_t v);
    // Read a bit.
    uint8_t read_bit(void);
    // Stop forcing power onto the bus. You only need to do this if
    // you used the 'power' flag to write() or used a write_bit() call
    // and aren't about to do another read or write. You would rather
    // not leave this powered if you don't have to, just in case
    // someone shorts your bus.
    void depower(void);
#if ONEWIRE_SEARCH
    // Clear the search state so that if will start from the beginning again.
    void reset_search();
    // Setup the search to find the device type 'family_code' on the next call
    // to search(*newAddr) if it is present.
    void target_search(uint8_t family_code);
    // Look for the next device. Returns 1 if a new address has been
    // returned. A zero might mean that the bus is shorted, there are
    // no devices, or you have already retrieved all of them.  It
    // might be a good idea to check the CRC to make sure you didn't
    // get garbage.  The order is deterministic. You will always get
    // the same devices in the same order.
    uint8_t search(uint8_t *newAddr);
#endif
#if ONEWIRE_CRC
    // Compute a Dallas Semiconductor 8 bit CRC, these are used in the
    // ROM and scratchpad registers.
    static uint8_t crc8(const uint8_t *addr, uint8_t len);
#if ONEWIRE_CRC16
    // Compute the 1-Wire CRC16 and compare it against the received CRC.
    // Example usage (reading a DS2408):
    //    // Put everything in a buffer so we can compute the CRC easily.
    //    uint8_t buf[13];
    //    buf[0] = 0xF0;    // Read PIO Registers
    //    buf[1] = 0x88;    // LSB address
    //    buf[2] = 0x00;    // MSB address
    //    WriteBytes(net, buf, 3);    // Write 3 cmd bytes
    //    ReadBytes(net, buf+3, 10);  // Read 6 data bytes, 2 0xFF, 2 CRC16
    //    if (!CheckCRC16(buf, 11, &buf[11])) {
    //        // Handle error.
    // @param input - Array of bytes to checksum.
    // @param len - How many bytes to use.
    // @param inverted_crc - The two CRC16 bytes in the received data.
    //                       This should just point into the received data,
    //                       *not* at a 16-bit integer.
    // @param crc - The crc starting value (optional)
    // @return True, iff the CRC matches.
    static bool check_crc16(const uint8_t* input, uint16_t len, const uint8_t* inverted_crc, uint16_t crc = 0);
    // Compute a Dallas Semiconductor 16 bit CRC.  This is required to check
    // the integrity of data received from many 1-Wire devices.  Note that the
    // CRC computed here is *not* what you'll get from the 1-Wire network,
    // for two reasons:
    //   1) The CRC is transmitted bitwise inverted.
    //   2) Depending on the endian-ness of your processor, the binary
    //      representation of the two-byte return value may have a different
    //      byte order than the two bytes you get from 1-Wire.
    // @return The CRC16, as defined by Dallas Semiconductor.
    static uint16_t crc16(const uint8_t* input, uint16_t len, uint16_t crc = 0);
#endif
#endif
#endif
Unfortunately I cannot reconstruct how I got to this solution but you might want to give it a try.
BryonMiller
by Johannesdewet on Tue Jul 25, 2017 12:54 pm
THANK YOU Bryon! I'll give this a try tonight.
Much appreciated!
Johannesdewet
by Johannesdewet on Tue Jul 25, 2017 11:13 pm
Bryon - Thank you!!
I followed your recommendations and it worked perfectly!
Can't thank you enough :) - I can now finally use my Temp sensor with the Feather.
Johannesdewet
by BryonMiller on Wed Jul 26, 2017 8:31 am
Glad it worked.
Bryon
BryonMiller
by billpurta on Tue Jan 08, 2019 2:28 am
I am having the same issue with the NRF52832 Bluefruit Feather receiving the following error...
C:\Users\User\Documents\Arduino\libraries\OneWire/OneWire.h:145:2: error: #error "Please define I/O register types here"
I tried replacing the onewire.h files as suggested in the earlier post that worked for the MO but it has the same disappointing outcome.
Any help to fix this would be greatly appreciated.
Bill
Update: I tried this again on a new PC with a new install of the Arduino IDE and new install of the one wire libraries--it WORKED!! I have been using onewire for several years on other Arduino boards successfully so I think the old files are not so current and need replacing.
Any tools out there to remove Arduino Libraries easily?
billpurta
by adafruit_support_mike on Wed Jan 09, 2019 12:57 am
Libraries per se will be in your sketchbook/libraries folder, and removing those is as simple as throwing the folders into the trash.
If you're running into problems with old versions of the board support packages, it's usually easiest to delete your whole Arduino15 folder and reinstall the latest board support packages from scratch.
