So just today I plugged in my Metro Mini 328 to my computer (Windows 10), and my computer gave the warning that the device malfunctioned. I looked in device manager and it showed the error "Unknown USB Device (Device Descriptor Request Failed)". The Arduino IDE also does not recognize the Metro Mini. I've tried multiple USB cables already that I know work for file transfer and I get the same problem. Also the red LED labeled "L" turns on then stays solid, which it never did before (See picture). Is there any way to fix this?
Thanks in advance
Metro Mini will not start/Is not recognized by Windows
- MiniMark33
Re: Metro Mini will not start/Is not recognized by Windows
The red LED is connected to pin 13, so having it light up just means the pin is high.
Just to check, have you installed the driver for the CP2104 USB-to-Serial converter?
https://learn.adafruit.com/adafruits-ra ... bs-chipset
- MiniMark33
I have not installed that, but the Metro Mini was being recognized earlier in Windows, it just suddenly stopped. When I get back to my computer I can try and install it, though I don't think it will fix it.
- MiniMark33
Installed the driver, same behavior. Hitting the reset button results in the same thing (On light and L light both on).adafruit_support_mike wrote:The red LED is connected to pin 13, so having it light up just means the pin is high.
If the USB host doesn't recognize the CP2104, it's probably a hardware problem. When did you get the board?
- MiniMark33
April 26th, 2017 is when I purchased it.
I'm sorry, but that's past our 30-day return/eplace period.
