Trinket M0 with FastLED
by Dance_Marks on Fri Sep 22, 2017 1:49 pm
I know ladyada kindly updated the FastLED library for the Gemma M0, is there plans to do the same for the Trinket M0?
Dance_Marks
Re: Trinket M0 with FastLED
by adafruit_support_mike on Fri Sep 22, 2017 11:41 pm
They both use the same microcontroller (the SAMD21E), so the update should work for both.
by Dance_Marks on Mon Sep 25, 2017 7:21 pm
I updated to the latest version of FastLED to test this. I think I bricked my Trinket M0.
Arduino 1.8.3
FastLED 3.1.6
I verified my code with Gemma M0 and it worked. I tried to verify for Trinket M0 and it didn't work.
I got the error "Invalid pin specified". I looked it up and I figured the library really wasn't working with the Trinket M0.
So I dug a little and I found in the file \platforms\avr\fastpin_arm_d21.h and I edited this line :
#elif defined(ARDUINO_GEMMA_M0)
for
#elif defined(ARDUINO_TRINKET_M0)
I verified and it worked, so naturally I tried to upload to my Trinket M0..
I got this result : https://pastebin.com/DVTDGL6K
And now my Trinket's green light is lit, the DotStar is purple, and my computer says "USB Device not recognized" when I plug it in, and it doesn't show in either the device manager or the IDE anymore.
I had obviously no idea what I was doing so I take full responsibility, just don't try this at home.
Dance_Marks
by adafruit_support_mike on Mon Sep 25, 2017 11:48 pm
The SAMD21 bootloader memory is write-protected, so it should be pretty hard to damage through regular interaction with the IDE.
Does the Trinket's NeoPixel pulse red when you double-click the reset button?
by Dance_Marks on Tue Sep 26, 2017 7:13 pm
I double clicked the reset button and my computer recognizes the Trinket M0 again. Thanks!
Dance_Marks
by adafruit_support_mike on Tue Sep 26, 2017 11:23 pm
Glad to hear it. Happy hacking!
by Dance_Marks on Fri Sep 29, 2017 10:16 am
adafruit_support_mike wrote:They both use the same microcontroller (the SAMD21E), so the update should work for both.
The gemma update doesn't work with the Trinket. I tried to tweak the library myself, but my knowledge in this area is limited and I haven't had success. I feel like it wouldn't be too complicated though, I just can't put my finger on it.
I realize FastLED is not your library and updating it from your end is a courtesy, but if you have any idea it would be greatly appreciated. I can't wait to develop on the Trinket M0.
Dance_Marks
by adafruit_support_mike on Fri Sep 29, 2017 11:47 pm
Try downloading a fresh copy from here:
https://github.com/adafruit/FastLED
Ladyada just tweaked a couple of things a few days ago.
by Dance_Marks on Sun Oct 01, 2017 9:10 pm
adafruit_support_mike wrote:Try downloading a fresh copy from here:
I tried it already without success. The latest commit to fastpin_arm_d21.h works only for the Gemma, even if they use the same chip, because the _DEFPIN_ARM hasn't been added for the Trinket M0.
Dance_Marks
by adafruit_support_mike on Sun Oct 01, 2017 11:57 pm
Hmm.. I'll pass that along to the software team.
by Dance_Marks on Mon Oct 02, 2017 2:43 pm
adafruit_support_mike wrote:Hmm.. I'll pass that along to the software team.
I appreciate it thank you!
Dance_Marks
by adafruit2 on Tue Oct 03, 2017 6:30 pm
did a PR, for now you can use....
adafruit2
Site Admin
by Dance_Marks on Tue Oct 03, 2017 7:37 pm
adafruit2 wrote:did a PR, for now you can use....
It works now, thank you so much!
Dance_Marks
by kgizzi on Sun Oct 08, 2017 8:41 pm
I can verify the fix did work! Thank you very much!
If you are using PlatformIO, you will need to manually make the change to .piolibdeps/FastLED_ID126/platforms/arm/d21/fastpin_arm_d21.h until the FastLED library changes get synced down to PlatformIO.
kgizzi
by daan1234 on Sun Nov 26, 2017 5:22 am
I followed the instructions above hoping to drive the on-board dotstar LED.
I use pin 7,8 for data and clock as in the documentation and get the invalid pin error. It seems that these two pins are not defined in fastpin_arm_21.h. Or is it something else?
daan1234
