I have been trying to program a ATTINY84 over ISP with an Arduino Uno. Whenever I try to upload the Blink sketch I get this error message. "avrdude: Yikes! Invalid device signature.
this check.
An error occurred while uploading the sketch"
I don't know if this is a problem with the computer, the Uno, or the ATTINY.
Ben
Problem using ArduinioISP to program ATTINY84
- btsprague
Re: Problem using ArduinioISP to program ATTINY84
What are you using as the build target under Tools->Board?
- btsprague
I am using the latest version(1.0.2) of the ATTINY board package
Ben
You might want to try one of the higher clock rates. By default, the ATtiny84's clock runs at up to 10MHz from a 3.3v supply and 20MHz from a 5v supply.
The 1MHz rate is a low-power mode that might require some fuse settings. I'm not sure really.. that isn't a chip we use.
