Trying to use my usbtiny programmer with avrdude:
$ sudo avrdude -p t2313 -c usbtiny -v -B 32
avrdude: Version 6.0.1, compiled on Oct 21 2013 at 15:55:32
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/etc/avrdude.conf"
User configuration file is "/home/adgm/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : usb
Using Programmer : usbtiny
Setting bit clk period : 32.0
avrdude: usbdev_open(): Found USBtinyISP, bus:device: 003:012
AVR Part : ATtiny2313
Chip Erase delay : 9000 us
PAGEL : PD4
BS2 : PD6
RESET disposition : possible i/o
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 6 4 0 no 128 4 0 4000 4500 0xff 0xff
flash 65 6 32 0 yes 2048 32 64 4500 4500 0xff 0xff
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 2 0 0 0 0 0x00 0x00
Programmer Type : USBtiny
Description : USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
avrdude: programmer operation not supported
avrdude: Setting SCK period to 32 usec
this check.
avrdude done. Thank you.
$ sudo avrdude -P /dev/ttyACM0 -p t2313 -b 19200 -c avrisp -v -B 32
Using Port : /dev/ttyACM0
Using Programmer : avrisp
Overriding Baud Rate : 19200
PAGEL : PD4
BS2 : PD6
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Programmer Type : STK500
Description : Atmel AVR ISP
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.05s
avrdude: Device signature = 0x000000 (retrying)
avrdude: Yikes! Invalid device signature.
this check.
These are all being programmed at 5v, and I have used both of the above avrdude commands with known good 2313's.
So the question is whether there are any other known issues that may be associated with ebay parts (e.g. other non-default fuse settings, etc). Any other ideas i could try? I'm willing to accept the possibility that these are entirely non-functioning parts -- if I have a way to verify that.
