I have a question about following display https://www.adafruit.com/product/2353.
I have the MCU that has build in driver for generating HSYNC,VSYNC,DCLK,DE and RGB data signals.
Is it possible to control this display only using MCU or i need to have additional drivers ?
In the datasheet for this display module i cant find information about what ic drivers are used and table with timing for synchronization signals.
For example, from the datasheet of this display https://www.adafruit.com/product/1596 i can see that it includes the combination of HX8264D + HX8664B drivers.
Timing table for synchronization signals is provided as well.
Thank you.
7 inch display RGB
Re: 7 inch display RGB
Both displays work with the RA8875 and TFP401 display drivers:
https://www.adafruit.com/product/1590
https://www.adafruit.com/product/2218
If the board you're using produces signals like those, it should work with either display.
