WINC1500 & Programmer Not Responding
For Adafruit customers who seek help with microcontrollers
nickolivo
Post by nickolivo »
I've got a WINC1500 shield attached to an Uno. When I run the Wifi Firmware Updater, I get a "Programmer Not Responding" error message when I click the Test Connection button. If I try to run the CheckWifi101FirmwareVersion sketch, the serial monitor shows
"WiFi101 firmware check."
"WiFi101 shield:"
and then never displays anything else.
I am able to upload other sketches to the board successfully.
I'm running Ubuntu 16.04 and 1.8.5 of the Arduino IDE. Please let me know what other information would be helpful.
adafruit_support_mike
Re: WINC1500 & Programmer Not Responding
That usually seems to be related to some kind of problem in the board support packages.
Try deleting (or just renaming) your Arduino15 folder, relaunch the Arduino IDE, and try doing a firmware update from the base version of the libraries.
nickolivo
Post by nickolivo »
I renamed Arduino15 and tried again, but am still encountering the same behavior. Is there something else I can try?
Thank you!
adafruit2
Post by adafruit2 »
hiya please post pics of your setup, it will help debug!
nickolivo
Post by nickolivo »
Here are the pics of my setup. I struggled with soldering the pins, but I don't think there's anything that's touching that shouldn't be. I was also able to upload and run the Blink sketch.
Thanks for the help!
adafruit2
Post by adafruit2 »
you are missing the 2x3 SPI header
nickolivo
Post by nickolivo »
I soldered on the other headers, but am still seeing the same behavior.
The full output of the console is:
java.lang.Exception: Programmer not responding
at cc.arduino.plugins.wifi101.flashers.java.FlasherSerialClient.hello(FlasherSerialClient.java:105)
at cc.arduino.plugins.wifi101.flashers.java.JavaFlasher.testConnection(JavaFlasher.java:51)
at cc.arduino.plugins.wifi101.UpdaterImpl$2.run(UpdaterImpl.java:110)
adafruit2
Post by adafruit2 »
try uploading the version checking script. what arduino is that?
nickolivo
Post by nickolivo »
The board I'm using is an Uno clone.
I uploaded the check version sketch and got this output in the Serial Monitor.
WiFi101 shield: DETECTED
Firmware version installed: 19.5.2
Latest firmware version available : 19.5.4
Check result: NOT PASSED
- The firmware version on the shield do not match the
version required by the library, you may experience
issues or failures.
Incidentally, when I go into the Firmware Updater, the most recent version I can select is 19.5.2. I'm running 1.8.5 of the IDE, is there something else I should update?
adafruit2
Post by adafruit2 »
you'll need to verify you have the latest version of the wifi101 library to get newer firmwares, i think!
nickolivo
Post by nickolivo »
The Library Manager says I have 0.14.5, which looks like it's the most recent version. Is there something else I can check?
adafruit2
Post by adafruit2 »
ooh here you go, looks like its a sepate thing! not sure why they didn't make it so it updates with the library >.<
https://github.com/arduino-libraries/Wi ... ter-Plugin
nickolivo
Post by nickolivo »
Ok, that got me the 19.5.4 firmware as an option, but I'm still getting the Programmer Not Responding error.
adafruit2
Post by adafruit2 »
it could be the non-standard arduino you have, what is it?
as an alternative, you can just back up the version of the wifi101 library until its happy with 19.5.2 - 19.5.4 doesnt add any features, its mostly bugfixes!
nickolivo
Post by nickolivo »
The board I'm using is an IEIK Uno.
I just tried with an official Arduino Uno, but got the same result.
I wound up backing out to an earlier version of the library and while I still get the programmer not responding error, I can successfully connect to my WiFi.
Thanks for all your help on this!
Return to “Microcontrollers”
