I have an nrf52 dev kit board from Nordic that comes with the SWD programmer. I would like to use it to program a feather or other custom nrf52 boards without the need for a bootloader.
I have no trouble uploading the bootloader through the Arduino IDE, but if I use Sketch->Upload Using Programmer I get the following error message: "Error while uploading: missing 'program.params.quiet' configuration parameter". Presumably, this functionality was never implemented for this board so there are just a bunch of configuration parameters like this one that are missing. I can happily populate them and even submit a pull request with the changes, but I need guidance with how to properly invoke `nrfjprog`.
I have the .hex and .map files that the Arduino IDE produced, but I do not know how to use `nrfjprog` to upload those. Could you point me towards some appropriate documentation?
nrf52 feather programming without a bootloader with nrfjprog
- stefankrastanov
- hathach
Re: nrf52 feather programming without a bootloader with nrfj
You need to modify arduino files (platform.txt, board.txt, programmer.txt) to the right command and parameters.
- stefankrastanov
Thanks! I am aware of that, and I even have some basic understanding of the command itself (nrfjprog).
The part I need help with is understanding how to appropriately invoke that command (just running nrfjprog on the produced hex file does not work - I am guessing because of a different memory layout).
- hathach
There is checksum test performed by bootloader to verify the application integrity. You could find more information in this issue
https://github.com/adafruit/Adafruit_nR ... issues/133
