Accessing all the pins on the Atmega32u4 breakout
by colinta on Wed Nov 07, 2018 12:25 pm
In particular, how do I access D5? Looking at the diagram at https://learn.adafruit.com/atmega32u4-breakout/design I see that, e.g. E6 is accessed using "pin 7" (pin mapping label is D7). But D5 doesn't have a pin mapping; usually it's hooked up to the TXLED.
Is there a way to control this pin in Arduino wiring code, or do we have to resort to using the PORTDx "commands" (which I know exist, but I'm not familiar with).
colinta
Re: Accessing all the pins on the Atmega32u4 breakout
by adafruit_support_mike on Thu Nov 08, 2018 12:51 am
That pin isn't broken out to the edge of the board, and the board support package doesn't provide a convenience mapping for the digitalWrite() function. To control that pin, you'll have to use PORTD bit manipulation.
That process isn't so bad.. PORTD is a register in the ATmega32u4's memory whose bits are mapped to physical pins at the edge of the chip. When you set a bit in PORTD, the corresponding pin goes high or low.
There's also a memory register named DDRD which controls the pin's configuration. Setting a bit in DDRD configures a pin as an output (the pin will mirror the value you set in PORTD), setting the bit to 0 configures the pin as an input (PORTD will mirror the signal connected to the pin).
This page shows the basics of port manipulation:
https://www.arduino.cc/en/Reference/PortManipulation
by colinta on Wed Nov 14, 2018 12:26 pm
Thanks, Mike! But D5 *is* broken out on the side... the only I/O pin I don't see is E2. Why is that, btw?
I'll use PORT/PIN/DDR registers, that works for me.
colinta
by colinta on Wed Nov 14, 2018 12:33 pm
Looking closely at the schematic... E2 goes to "HWB" - aka reset button? or is this a "do what you want" button? D5 is wired to an LED. Again is this for funsies?
colinta
by adafruit_support_mike on Fri Nov 16, 2018 12:48 am
Sorry, I was looking at the wrong schematic.
Referring to this one:
https://cdn-learn.adafruit.com/assets/a ... 1473702355
the pin identifed as PORTD5 in the ATmega32u4 datasheet connects to a pin labeled D5.
That board has been discontinued, which was part of my confusion.
The /HWB signal is a built-in feature of the ATmega32u4 described in section 10.3.5 of the datasheet. The full name is Harware Bootloader. If the HWBE flag is set and /HWB is pulled low when the chip resets, the chip will execute firmware loaded in its protected bootloader memory when it starts up. If /HWB is left high during a reset, the chip will start executing the firmware in its bootloader-programmable memory.
cron
