Teensy 3.6 CAN Trouble
by beermedude on Fri Nov 09, 2018 10:18 pm
I am having trouble getting CAN to work with my Teensy 3.6. I have read that I should use the FlexCAN library? All I am trying to do is read some RPM data from a ECU then drive a Neopixel ring as a tachometer. I got the ring working now I need the CAN part to work. My ECU broadcasts data in 2 bytes and in HEX. I know how to convert the given CAN data to an int. Just don't know how to read it... Any ideas? Thanks!
beermedude
Re: Teensy 3.6 CAN Trouble
by adafruit_support_mike on Sun Nov 11, 2018 12:30 am
I'm afraid we don't have much experience doing CAN on the Teensy platform. Your best bet will be to check over in the PJRC forums, which are the Teensy's home:
https://forum.pjrc.com/
