apt-get update stop on Raspberry PI 3
by gzampatti on Fri Nov 30, 2018 2:17 pm
on Raspberry pi 3 firmware version:
XXXXX:~ $ uname -a
Linux XXXXX 4.9.35-v7+ #1014 SMP Fri Jun 30 14:47:43 BST 2017 armv7l GNU/Linux
command sudo apt-get update stop with this error:
XXXXXX:~ $ sudo apt-get update
Trovato http://archive.raspberrypi.org jessie InRelease
Trovato http://mirrordirector.raspbian.org jessie InRelease
Trovato http://archive.raspberrypi.org jessie/main armhf Packages
Trovato http://archive.raspberrypi.org jessie/ui armhf Packages
Scaricamento di:1 http://apt.adafruit.com jessie InRelease [312 B]
Ign http://apt.adafruit.com jessie InRelease
Scaricamento di:2 http://apt.adafruit.com jessie Release.gpg [314 B]
Ign http://apt.adafruit.com jessie Release.gpg
Scaricamento di:3 http://apt.adafruit.com jessie Release [310 B]
Ign http://archive.raspberrypi.org jessie/main Translation-it_IT
Scaricamento di:4 http://apt.adafruit.com jessie/main armhf Packages [333 B]
Ign http://archive.raspberrypi.org jessie/main Translation-en
Ign http://archive.raspberrypi.org jessie/ui Translation-it_IT
Scaricamento di:5 http://apt.adafruit.com jessie/main Translation-it_IT [334 B]
Ign http://archive.raspberrypi.org jessie/ui Translation-en
Trovato http://mirrordirector.raspbian.org jessie/main armhf Packages
Scaricamento di:6 http://apt.adafruit.com jessie/main Translation-it [331 B]
Trovato http://mirrordirector.raspbian.org jessie/contrib armhf Packages
Scaricamento di:7 http://apt.adafruit.com jessie/main Translation-en [331 B]
Trovato http://mirrordirector.raspbian.org jessie/non-free armhf Packages
Scaricamento di:8 http://apt.adafruit.com jessie/main armhf Packages [333 B]
Trovato http://mirrordirector.raspbian.org jessie/rpi armhf Packages
Scaricamento di:9 http://apt.adafruit.com jessie/main Translation-it_IT [334 B]
Scaricamento di:10 http://apt.adafruit.com jessie/main Translation-it [331 B]
Scaricamento di:11 http://apt.adafruit.com jessie/main Translation-en [331 B]
Scaricamento di:12 http://apt.adafruit.com jessie/main armhf Packages [333 B]
Scaricamento di:13 http://apt.adafruit.com jessie/main Translation-it_IT [334 B]
Scaricamento di:14 http://apt.adafruit.com jessie/main Translation-it [331 B]
Scaricamento di:15 http://apt.adafruit.com jessie/main Translation-en [331 B]
Scaricamento di:16 http://apt.adafruit.com jessie/main armhf Packages [333 B]
Scaricamento di:17 http://apt.adafruit.com jessie/main Translation-it_IT [334 B]
Scaricamento di:18 http://apt.adafruit.com jessie/main Translation-it [331 B]
Scaricamento di:19 http://apt.adafruit.com jessie/main Translation-en [331 B]
Scaricamento di:20 http://apt.adafruit.com jessie/main armhf Packages [333 B]
Err http://apt.adafruit.com jessie/main armhf Packages
  HttpError404
Scaricamento di:21 http://apt.adafruit.com jessie/main Translation-it_IT [334 B]
Ign http://apt.adafruit.com jessie/main Translation-it_IT
Scaricamento di:22 http://apt.adafruit.com jessie/main Translation-it [331 B]
Scaricamento di:23 http://apt.adafruit.com jessie/main Translation-en [331 B]
Ign http://apt.adafruit.com jessie/main Translation-en
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-it_IT
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en
Ign http://mirrordirector.raspbian.org jessie/main Translation-it_IT
Ign http://mirrordirector.raspbian.org jessie/main Translation-en
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-it_IT
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-it_IT
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en
W: Impossibile recuperare http://apt.adafruit.com/raspbian/dists/jessie/main/binary-armhf/Packages  HttpError404
I have executed sudo apt-get upgrade and sudo apt dist-upgrade with success
Thank you
gzampatti
Re: apt-get update stop on Raspberry PI 3
by adafruit_support_mike on Sat Dec 01, 2018 2:06 am
We shut down our apt server a few months ago because it was no longer necessary. All of our code has been merged into the main packages.
We tried to update all the scripts and tutorials that mentioned the apt server, but could have missed a few. Could you post a link to the project or tutorial you were following please?
by gzampatti on Sat Dec 01, 2018 4:29 am
This is a Adafruit solution I used, but at the moment I'm not using it anymore:
https://www.adafruit.com/product/3538
For my project I use only ADAFRUIT BME280 (I2C) and ADAFRUIT ULTIMATE GPS BREAKOUT
Best Regards
gzampatti
by adafruit_support_mike on Mon Dec 03, 2018 1:35 am
You can remove the line:
deb http://apt.adafruit.com/raspbian/ jessie main
from /etc/apt/sources.list
by gzampatti on Mon Dec 03, 2018 8:29 am
Thanks a lot.
Now work fine.
Best regards
gzampatti
