Playground express Conflicting CPU architectures 0/12
by procyon75 on Sun Dec 02, 2018 2:47 pm
Hi !
I used Arduino IDE on Mac Os X.13 with an Adafruit Huzzah feather Esp8266 and all was good.
Then I bought a Playground Express, downloaded Arduino SAMD boards kit for 32b arm cortex m0+.
And I can't compile a sketch nor download it to the card.
My card type is set to "Playground express".
Card info gives vid/pid 239a 8019 and the bn is either unknown card or "Adafruit circuit Playground express" so the USB communication are good.
With all the latest versions : IDE is 1.8.7, the ARM kit is 1.6.20.
If I start with hello-blink example it starts with an include error :
In file included from sketch/Hello_Blink.ino.cpp:1:0:
/Users/xxx/Library/Arduino15/packages/arduino/hardware/samd/1.6.20/cores/arduino/Arduino.h:124:0: warning: "digitalPinToInterrupt" redefined [enabled by default]
 #define digitalPinToInterrupt(P)   ( P )
In file included from /Users/xxx/Library/Arduino15/packages/arduino/hardware/samd/1.6.20/cores/arduino/delay.h:23:0,
                 from /Users/xxx/Library/Arduino15/packages/arduino/hardware/samd/1.6.20/cores/arduino/Arduino.h:81,
/Users/xxx/Library/Arduino15/packages/arduino/hardware/samd/1.6.20/variants/circuitplay/variant.h:54:0: note: this is the location of the previous definition
 #define digitalPinToInterrupt(P) (g_APinDescription[P].ulExtInt)
I get this error a lot of times, then for linking
Users/xxx/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: libraries/Adafruit_Circuit_Playground/utility/ffft.S.o: Conflicting CPU architectures 12/0
and a lot of variants
/Users/xxx/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: /Users/xxx/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv6-m/libm.a(lib_a-s_fpclassify.o): Conflicting CPU architectures 0/12
I tried deleting SAM kit and reinstalling it.
I tried switching to another card and back to this one but no change.
On the net everyone seems to do python and make code :-(
C needs love too.
procyon75
Re: Playground express Conflicting CPU architectures 0/12
by adafruit_support_mike on Mon Dec 03, 2018 1:38 am
That's a bug in the 1.8.7 version of the Arduino IDE. Drop back to an earlier version like 1.8.6 and things should work normally.
by procyon75 on Mon Dec 03, 2018 6:40 pm
I tried 1.8.6 with and without a reinstallation of SAM kit 1.6.20 => nope.
I tried 1.8.5 => nope
I tried lastest arduino beta 2018 11 30 => nope
Then I tested arduino 1.8.5 with SAM kit 1.6.19 => nope
Then I tested arduino 1.8.5 with SAM kit 1.6.18 => nope
always the same
/Users/xxx/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino/Arduino.h:124:0: warning: "digitalPinToInterrupt" redefined [enabled by default]
In file included from /Users/xxx/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino/delay.h:23:0,
                 from /Users/xxx/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/cores/arduino/Arduino.h:81,
/Users/xxx/Library/Arduino15/packages/arduino/hardware/samd/1.6.18/variants/circuitplay/variant.h:54:0: note: this is the location of the previous definition
and
/Users/xxx/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: libraries/Adafruit_Circuit_Playground/utility/Adafruit_CPlay_LIS3DH.cpp.o: Conflicting CPU architectures 0/12
/Users/xxx/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: libraries/Adafruit_Circuit_Playground/utility/Adafruit_CPlay_NeoPixel.cpp.o: Conflicting CPU architectures 0/12
/Users/xxx/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: libraries/Adafruit_Circuit_Playground/utility/CP_Firmata.cpp.o: Conflicting CPU architectures 0/12
/Users/xxx/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: libraries/Adafruit_Circuit_Playground/utility/IRLibDecodeBase.cpp.o: Conflicting CPU architectures 0/12
/Users/xxx/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: libraries/Adafruit_Circuit_Playground/utility/IRLibProtocols.cpp.o: Conflicting CPU architectures 0/12
/Users/xxx/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: libraries/Adafruit_Circuit_Playground/utility/IRLibRecvPCI.cpp.o: Conflicting CPU architectures 0/12
/Users/xxx/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: libraries/Adafruit_Circuit_Playground/utility/IRLibSendBase.cpp.o: Conflicting CPU architectures 0/12
/Users/xxx/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: libraries/Wire/Wire.cpp.o: Conflicting CPU architectures 0/12
/Users/xxx/Library/Arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/bin/ld: error: core/variant.cpp.o: Conflicting CPU architectures 0/12
procyon75
by adafruit_support_mike on Tue Dec 04, 2018 1:00 am
Hmm.. those directory paths look wrong.
Are you using the Circuit Playground Express build target that's part of the Arduino Boards section of the Tools->Board menu, or the one under the Adafruit SAMD Boards section?
by procyon75 on Sun Dec 16, 2018 12:59 pm
demo and blink compile OK with arduino 1.8.5 with SAM kit 1.6.18 and card = Arduino AVR / Adafruit circuit playground
but if I switch to card = Arduino SAMD / Adafruit circuit playground Express I get the (now classic) nonsense.
I don't have any other Circuit Playground option to choose.
I fiddled with the library folder. Deleting folders, restoring some ..
I don't know what I did exactly but after a lot of errors it finally compiles with 1.8.5.
I have the tool version SAM 1.6.20.
And in libraries I have both a 1.6.7 Adafruit Circuit Playground lib and a 1.8.1
If I switch to Arduino IDE 1.8.6 it compiles OK too. It sees only Adafruit Circuit Playground lib 1.8.1
A clean install shall be needed for arduino IDE because it's a mess.
But I'm still not safe.
In boot loader mode (green led + slow pulsing red), the code download starts then
No device found on cu.usbmodem1441
Une erreur est survenue lors du transfert du croquis => Error when downloading.
The device can be probed, but can't download anything.
I am doomed.
procyon75
by Willamid on Mon Dec 17, 2018 3:28 am
I am having the same issue with my Circuit Playground Express. I reinstalled all libraries, drivers and packages. I also tried Arduino 1.8.4 and 1.8.5, SAMD package 1.6.19 and 1.6.18 and also tested everything on 2 other PCs but I am still getting a full page of errors. Does anybody have any idea what this is? The error below is only a part of the debugging message but all lines have the same format.
C:\Users\xxx\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.19\cores\arduino/Arduino.h:124:0: warning: "digitalPinToInterrupt" redefined [enabled by default]
In file included from C:\Users\xxx\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.19\cores\arduino/delay.h:23:0,
                 from C:\Users\xxx\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.19\cores\arduino/Arduino.h:81,
                 from sketch\Hello_Blink.ino.cpp:1:
C:\Users\xxx\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.6.19\variants\circuitplay/variant.h:54:0: note: this is the location of the previous definition
Could it be Windows 7 being incompatible or something? I've tried to debug this for a week now, so any help would be appreciated.
Willamid
by adafruit_support_mike on Tue Dec 18, 2018 2:04 am
@Willamid: Please start a new thread for your issue. Trying to debug more than one problem in a thread is just asking for confusion.
@procyon75: Install the "Arduino SAMD Boards" and "Adafruit SAMD Boards" board support packages.
Delete any CircuitPlayground libraries you have in sketchbook/libraries.
Install a fresh copy of this one:
https://github.com/adafruit/Adafruit_CircuitPlayground
Reboot the Arduino IDE.
Select "Adafruit Circuit Playground Express" from the "Adafruit SAMD Boards" section of the Trools->Board menu, -NOT- the version under the Arduino SAMD Boards section.
Try to upload the Blink sketch, and post any output from the debug pane if it doesn't work.
by procyon75 on Sat Dec 29, 2018 3:21 pm
Hi !
I deleted the circuit playground library in my folder.
I installed "Arduino SAMD Boards". No "adafruit board" available.
Then downloaded Adafruit_CircuitPlayground-1.8.1 from your link and installed it.
But I have only one section "Arduino SAMD" with both Arduino boards and one Adafruit.
I included a snapshot.
I tried arduino 1.8.8, it looks and does the same.
I get the same redefinitions warning when compiling and the download always stops before completion.
procyon75
by adafruit_support_mike on Sun Dec 30, 2018 12:41 am
Open the Arduino IDE's Preferences panel, and add this URL to "Additional Board Manager URLs":
https://adafruit.github.io/arduino-boar ... index.json
Restart the Arduino IDE, and install the Adafruit SAMD Boards support package.
