stk500 adapter
stk500 adapter
by SuperMiguel on Thu Feb 11, 2010 12:42 pm
you guys think that this adapter: http://www.adafruit.com/index.php?main_ ... ucts_id=63 will work with an stk500 board??
SuperMiguel
Re: stk500 adapter
by FazJaxton on Thu Feb 11, 2010 1:48 pm
I think the STK500 requires something like 7-12 V, and 660mA is more than enough current, so electrically it should be fine. I think the only question is whether the plug itself will fit in the jack. I have both at home, so I'll try it out and let you know.
FazJaxton
Re: stk500 adapter
by SuperMiguel on Thu Feb 11, 2010 2:39 pm
thanks you
SuperMiguel
Re: stk500 adapter
by FazJaxton on Thu Feb 11, 2010 9:59 pm
I plugged in the one from my Ice Tube clock (same specs 9V, 0.66A) into my board and it powered on OK. However, the documentation for my board says that it requires 10-15V input, so 9V may not be enough to fully power the board. You might want to check the specs for your board, and unless they're different, look for a higher-voltage adaptor.
FazJaxton
Re: stk500 adapter
by SuperMiguel on Thu Feb 11, 2010 10:37 pm
well i think the schematics for the board say 9v not sure..
http://support.atmel.no/knowledgebase/a ... STK500.pdf
SuperMiguel
Re: stk500 adapter
by FazJaxton on Fri Feb 12, 2010 12:21 pm
If that's true, then it should be fine. I was just going by what my documentation says. No guarantees from me, though. :)
FazJaxton
