Arduino bootloader-programmed chip
by allenn on Fri Dec 28, 2018 10:45 am
I purchased 3 Arduino bootloader-programmed chips Atmega 328P). None function in the Arduino Uno. They will not run a simple blink sketch. The original chip will run the blink sketch. As I understand it, this is how I am to communicate with Adafruit support.
allenn
Re: Arduino bootloader-programmed chip
by adafruit_support_bill on Fri Dec 28, 2018 11:04 am
When you power-up the UNO with the chip installed, is there any LED activity on the board?
by allenn on Fri Dec 28, 2018 1:19 pm
the on led is on, and the led next to the letter L is on
allenn
by adafruit_support_bill on Fri Dec 28, 2018 1:21 pm
Is the one next to the 'L' steady on, or does it flash a few times?
by allenn on Fri Dec 28, 2018 1:30 pm
When the board is powered up pin 13's on board LED is illuminated. When I check the voltage of pin 13 I am reading only .15. The chip does not accept programs.
allenn
by allenn on Fri Dec 28, 2018 2:23 pm
It seems to flash about 4 times, then it is steady on (at power up).
allenn
by adafruit_support_bill on Fri Dec 28, 2018 2:31 pm
OK. It sounds like the bootloader is active. When you try to upload your blink program, what is the error output from the Arduino IDE? Is there any LED activity when you attempt the upload?
by allenn on Fri Dec 28, 2018 2:40 pm
Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xb1
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xb1
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xb1
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xb1
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xb1
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xb1
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xb1
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xb1
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xb1
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xb1
allenn
by adafruit_support_bill on Fri Dec 28, 2018 2:43 pm
by allenn on Fri Dec 28, 2018 2:53 pm
Pin 13 'L' LED flashes 3 times and then remains on. Very rarely does TX or RX flash, when they do it is a quick dull flash.
allenn
by adafruit_support_bill on Fri Dec 28, 2018 3:33 pm
The problem is the board type selection. The "Adaboot" bootloader programmed onto those chips is compatible with the Duemilanove bootloader. So you need to select "DUEMILANOVE with ATMEGA328" as your board type in the Arduino IDE. All other capabilities are identical with the UNO.
by allenn on Fri Dec 28, 2018 3:45 pm
Working now, thank you.
allenn
by adafruit_support_bill on Fri Dec 28, 2018 4:45 pm
Good to hear! Thanks for the update.
