convert Adafruit library c++ to c
by Joudi on Mon Feb 11, 2019 2:07 pm
I'm trying to convert Adafruit library from c++ to c. The sensor name is SI1145 and i have a problem with this part.
in .cpp file:
uint16_t _read16(uint8_t a) {
  uint16_t ret;
  Wire.beginTransmission(_addr); // start transmission to device
  Wire.write(a); // sends register address to read from
  Wire.endTransmission(); // end transmission
  Wire.requestFrom(_addr, (uint8_t)2);// send data n-bytes read
  ret = Wire.read(); // receive DATA
  ret |= (uint16_t)Wire.read() << 8; // receive DATA
  return ret;
in .h file the parameters are a little bit different.
uint16_t _read16(uint8_t addr);
I don't really get why one says "a" and the other says "address". How do I properly convert the parameters?
Joudi
Re: convert Adafruit library c++ to c
by adafruit_support_bill on Mon Feb 11, 2019 2:11 pm
The .h file is just defining the call signature for that function. The number, type and order of the parameters are important. The parameter names are not.
