๐ŸŽ„โ›„โ„๏ธ๐ŸŽ It's beginning to look a lot like ADABOX-mas! The next ADABOX from Adafruit ships soon! Get yours now, or give as a gift! ๐ŸŽ„โ›„โ„๏ธ๐ŸŽ
Huzzah ESP8266 to Audio FX
by bobhatestowels7 on Wed Feb 27, 2019 2:48 pm
I'm attempting to use a Huzzah ESP8266 to control the Audio FX sound board via serial.
I've followed the basic directions from here for Arduino: https://learn.adafruit.com/adafruit-aud ... io-control
I've adjusted the pins in the code to the ones I'm using on the Huzzah. Code compiles fine and loads, however when running I get the error "Not found" when trying to connect to the sound board.
Serial output:
Adafruit Sound Board!
Not found
Soft WDT reset
>>>stack>>>
ctx: cont
sp: 3ffffdf0 end: 3fffffc0 offset: 01b0
3fffffa0:  feefeffe feefeffe 3ffee780 40203b24
3fffffb0:  feefeffe feefeffe 3ffe84f4 40100e8d
<<<stack<<<
 ets Jan  8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
v951aeffa
~ld
Not found
Updated Adafruit soundboard example
#include <SoftwareSerial.h>
#include "Adafruit_Soundboard.h"
// Choose any two pins that can be used with SoftwareSerial to RX & TX
#define SFX_TX 14
#define SFX_RX 12
// Connect to the RST pin on the Sound Board
#define SFX_RST 13
bobhatestowels7
Re: Huzzah ESP8266 to Audio FX
by adafruit_support_mike on Thu Feb 28, 2019 1:34 am
Your connections look like they're correct.
For sanity checks, measure the voltage between the FX Board's Vin and GND pins at the board (the solder joints under the pin header if possible), and try doing a loopback test on the SoftwareSerial connection: connect a jumper between the terminals that plug onto the FX Board's pins, then write a quick sketch that sends data out with ss.write() then checks to see if it comes back on ss.read().
by bobhatestowels7 on Thu Feb 28, 2019 1:16 pm
Thanks support_mike,
Voltage is 4.96.
As a sanity check, I disconnected UG from GND, restarted, and was then able to play files using the pin triggers.
I also connected my console cable directly to TX & RX on the Audio FX board, and was then able to communicate directly with the board -- playing files, listing files, etc. So the FX side of things seems to be all good.
The loopback test on SoftwareSerial was not so good, assuming my simple sketch is OK. (Which it may very well not be...)
  // softwareserial at 9600 baud
  ss.begin(9600);
  // can also do Serial1.begin(9600)
  ss.write("Test");
  Serial.println(ss.read());
That's returning a value of -1 when run.
I've checked the Arduino libraries, and I do have the ESP version of SoftwareSerial at /ArduinoData/packages/esp8266/hardware/esp8266/2.5.0/libraries/SoftwareSerial.
bobhatestowels7
by adafruit_support_mike on Fri Mar 01, 2019 3:00 am
Try moving the TX and RX signals to pins 2 and 3.
Pins 12-14 are also used for SPI, and may already be allocated by the basic runtime.
by bobhatestowels7 on Fri Mar 01, 2019 1:04 pm
No pin 3 on the board. And I had been avoiding 2 as it's used for boot mode and connected to the blue LED.
https://learn.adafruit.com/adafruit-huz ... ll#pinouts
bobhatestowels7
by adafruit_support_mike on Sat Mar 02, 2019 12:09 am
Right, sorry, I was thinking about the Feather version.
Try moving TX and RX around on the pins that are available, but also try swapping the jumpers you're using. Wire can break inside the insulation, making circuits fail even though they look good.
