HUZZAH ESP8266 WiFi connection not working
by jonpb on Sat Mar 02, 2019 8:26 pm
Putty and nodemcu-tool both connect and I am able to upload and run lua scripts.
Also the gpio library is working, but I'm having problems with the wifi and net libraries.
The following code fails on wifi.ap.config:
assert(wifi.setmode(wifi.STATIONAP))
cfg={}
cfg.ssid="pageflip"
cfg.pwd="electrosolve"
assert(wifi.ap.config(cfg))
The error is:
bad argument #1 to 'assert' (value expected)
Also, if I try to flash a new firmware, esptool.py v2.6 does not connect, giving the following error:
COM3 failed to connect: Failed to connect to Espressif device: Timed out waiting for packet header
jonpb
