Which mcu could best suit wifi project
by knowthebird on Sun Mar 03, 2019 8:24 pm
Good afternoon,
I am going to be working on a project using the Adafruit 9-DOF IMU and ADXL377 - High-G Triple-Axis Accelerometer. Links below are for the products I am referring to. I have a few other requirements. I need to be able to log the information to an SD Card, and send the information over W-Fi. I would also like to keep the device small in size.
https://www.adafruit.com/product/2472
https://www.adafruit.com/product/1413
Lastly, and ideally, I would like a WiFi AP to run on the device, so that any phone or computer could connect to it, and see the data in real time similar to the bunny example below:
https://learn.adafruit.com/adafruit-bno055-absolute-orientation-sensor/processing-test
Originally I was thinking of using a raspberry pi zero w, but I believe I will also need to purchase an analog to digital converter, and then saw the following warning in documentation:
Raspberry Pi computers do not have I2C clock stretching support so they don't work well with the BNO055 - there's hacky workarounds, but it's not recommended!
So now I am not sure what device to use, and I see a lot of options to filter through. I do not mind coding with Arduino IDE or Python. I am considering using the feather m0 wifi and sd card feather wing below, but I am open.
https://www.adafruit.com/product/3010
https://www.adafruit.com/product/2922
Any and all advice on choosing the best hardware is appreciated. My budget can wiggle, and so can the setup. I just want to choose what would work best for these requirements.
Thank you for any and all help.
knowthebird
Re: Which mcu could best suit wifi project
by adafruit_support_mike on Mon Mar 04, 2019 12:38 am
The other option for a microcontroller would be the ESP8266, which has built-in Wifi:
https://www.adafruit.com/product/2821
It only has one 0V-1V ADC, but costs about half as much as the Feather M0 + WINC1500. You could add a Seesaw GPIO expander with three 12-bit ADC pins for less than the difference:
https://www.adafruit.com/product/3657
Either Feather can operate as a WAP, and both will work with the Adalogger FeatherWing.
by knowthebird on Mon Mar 04, 2019 2:33 am
Thank you for the feedback!
knowthebird
