Confused about micro controllers
by Proteus1985 on Thu Mar 07, 2019 7:48 am
Hi there
Sorry if this question has been asked already but I have searched through the forum, watched several videos and I’m still confused when it comes to micro controllers.
I have a project I’m Egar to get started but I ksit don’t know which micro controller will be best for my project.
This community seems so helpful I thought I would take the plunge and reach out for some help.
My project is simple, it contains 7 leds of which 4 I hope to be super bright, 4 push button switches, 1 window sensor, 6 sound fxs, 1 servo
I am just confused at to which of the micro controllers to use, I think i might be heading for the metro? But I’m just not sure.
I really appreciate any help at all.
Thank you
Proteus1985
Re: Confused about micro controllers
by adafruit_support_bill on Thu Mar 07, 2019 9:31 am
Not sure what type of window sensor you plan to use. But I am assuming that by "6 sound fxs" you mean that you have 6 different sounds that you want to trigger via an FX board.
Assuming that your window sensor only needs 1 pin, you are looking at 19 GPIO pins. The Metro M0 would just cover it with exactly 19 pins.
by Proteus1985 on Thu Mar 07, 2019 9:49 am
Hi bill
Thank you very much for the response.
The window sensor is a independent unit I intend to take apart and fit into my circuit, it triggers a switch when the 2 parts are separated and activates a buzzer, I don’t want the buzzer just the was the switch works.
Yeah I intend to use the adafruit sound fx board to trigger the 6 sounds, but at the same time the sounds play leds will change.
Metro MO it is then, thank you again for the help
Proteus1985
