USB Malfunction
Re: USB Malfunction
by dcharato on Mon Apr 01, 2019 8:23 am
Tried it with both devices and on multiple computers. Still not working.
dcharato
Re: USB Malfunction
by adafruit_support_mike on Tue Apr 02, 2019 1:52 am
Let's try one more thing: put a cheap/old USB-2 hub between the computer and the Feathers. There are known problems with microcontroller bootloaders trying to talk to USB-3 ports, and having two boards fail the same way strongly suggests a reaction to something in the operating environment.
Re: USB Malfunction
by dcharato on Fri Apr 05, 2019 11:37 am
adafruit_support_mike wrote:Let's try one more thing: put a cheap/old USB-2 hub between the computer and the Feathers. There are known problems with microcontroller bootloaders trying to talk to USB-3 ports, and having two boards fail the same way strongly suggests a reaction to something in the operating environment.
Ok. Sorry was out of the building. I will grab my USB 2.0 hub and try it on Monday.
dcharato
Re: USB Malfunction
by dcharato on Mon Apr 08, 2019 8:58 am
still not working.
Could a laptop be putting to much power to the device and blowing out the USB? Not sure what else would cause two to stop working on the upload?
Just as FYI. I have used the same USB cable on two Circuit playground express with no issues
dcharato
Re: USB Malfunction
by adafruit_support_mike on Mon Apr 08, 2019 11:35 pm
No, a standard power supply can't force current through a circuit. The circuit only uses as much current as it can.
It sounds like the Feather's USB hardware has failed. Send a note containing a link to this page and your order number to support@adafruit.com and the folks there will get you a replacement Feather 32u4 BLE.
(#2829)
Re: USB Malfunction
by MACDEVSTUDIO on Fri Sep 06, 2019 5:24 pm
Hi. I recently purchased a Feather M0 Bluefruit LE from your Amazon store and I am experiencing the exact same behavior. Would you be able to help me with the issue. Thank you!
MACDEVSTUDIO
