Pyportal Display
Pyportal Display
by toddmac12 on Tue Mar 26, 2019 8:37 pm
The display on my Pyportal only shows a bright screen. I have checked and reinserted the display ribbon but it still has the same display. I have attached the code I am using and snapshots of the files on the device.
circuitipy drive.jpg (39.63 KiB) Viewed 202 times
lib file list.jpg (242.45 KiB) Viewed 202 times
code.txt
(1.32 KiB) Downloaded 44 times
toddmac12
Re: Pyportal Display
by adafruit_support_carter on Wed Mar 27, 2019 3:09 pm
Was this one of the ones from AdaBox011? Go ahead and try the update process here:
https://learn.adafruit.com/adafruit-pyp ... r-pyportal
Note that to get WiFi working you'll need to edit the secrets.py file:
https://learn.adafruit.com/adafruit-pyp ... -file-17-1
by toddmac12 on Wed Mar 27, 2019 5:51 pm
Yes, it is from Adabox 011. I have installed the updates but the screen is still bright and blank!! I used the MU Serial and have found that the program code is working but the Pyportal does not display the results.
toddmac12
by adafruit_support_carter on Wed Mar 27, 2019 5:58 pm
See if it might be the ribbon cable on the back:
https://learn.adafruit.com/adafruit-pyp ... -faq#faq-2
by toddmac12 on Wed Mar 27, 2019 8:22 pm
I tried reinserting the cable again but I still have the bright blank display.
toddmac12
by adafruit_support_carter on Thu Mar 28, 2019 12:45 pm
OK, it might still be software related. Part of this may the firmware and libraries also. Let's first check the version of the CircuitPython firmware you are running. To do that, paste the contents of the boot_out.txt file here.
by toddmac12 on Thu Mar 28, 2019 12:54 pm
I have figured out the problem. The ribbon connection for the display is broken. How can I get a replacement?
toddmac12
by adafruit_support_carter on Thu Mar 28, 2019 1:00 pm
Oh wow, that would explain it. Can you post a photo. We'll replace it. Just want to document what happened.
by toddmac12 on Thu Mar 28, 2019 3:44 pm
I have attached a photo of the display ribbon.
toddmac12
by adafruit_support_carter on Thu Mar 28, 2019 4:16 pm
Thanks. Let's replace it. Send an email to support@adafruit.com with a link to this thread and they can get you a replacement PyPortal. Sorry about the broken ribbon cable.
