๐ŸŽ„โ›„โ„๏ธ๐ŸŽ It's beginning to look a lot like ADABOX-mas! The next ADABOX from Adafruit ships soon! Get yours now, or give as a gift! ๐ŸŽ„โ›„โ„๏ธ๐ŸŽ
Adafruit STEMMA Soil Sensor Adress Change
by max22 on Thu Jun 06, 2019 2:13 am
i have 8 Sensors from :
https://learn.adafruit.com/adafruit-ste ... or/pinouts
on a ESP 8266 i test the sensor with:
https://github.com/adafruit/Adafruit_Se ... xample.ino
it work' s
but how can i change the Adress from 0x36 to 0x33 or so on.
i found the Discription:
There's also two I2C address jumpers. The default address is 0x36, but you can select between 0x36 and 0x39 inclusive by shorting AD0 (to add 1 to the address) and/or AD1 (to add 2 to the address)
but when i will add 8 Sensors ??
how can help me ? is there a way to change the Adress with code ?
Thanks a lot Max
max22
Re: Adafruit STEMMA Soil Sensor Adress Change
by franklin97355 on Thu Jun 06, 2019 2:41 am
Take a look at the i2c multiplexer chip to add more addresses.
franklin97355
by max22 on Thu Jun 06, 2019 4:41 pm
Oh thanks,
i'm very new to coding ESP 8266 can you give me an example of code for Adress Changing and Moisture read
of MoistureSensors.
max22
