ESP32 interrupt
ESP32 interrupt
by Workaholic on Fri Jul 05, 2019 3:17 am
Hey guys. I want to know if we can implement interrupt in esp32 using arduino ide, Otherwise, what is a good way to handle serial data.
Regards,
Workaholic
Re: ESP32 interrupt
by adafruit_support_mike on Sun Jul 07, 2019 2:16 am
If you want to use Serial data, use one of the hardware Serial ports.
One port is dedicated to talking to the USB cable, but a second one is connected to the TX/RX pins at the side of the board. That interface is identified as Serial1 in code, and is free to connect to anything.
There's also a third, uncommitted Serial interface that you can define if you want to. The code for assigning it to a set of pins looks like this:
HardwareSerial Serial2( 2 );
#define SERIAL2_RX 12
#define SERIAL2_TX 13
  Serial2.begin( 9600, SERIAL_8N1, SERIAL2_RX, SERIAL2_TX );
Re: ESP32 interrupt
by Workaholic on Mon Jul 08, 2019 2:50 am
Thanks.
I will try this.
Workaholic
