Mini Push-Pull Solenoid - 5V
by kidcopernicus on Mon Jul 08, 2019 1:02 pm
Finding the wiki a bit problematic.. Was the wiki database damaged somehow? Thought it was uBlock at first..
Anyway, I'm buying the Mini Solenoid here: https://www.adafruit.com/product/2776
Very excited to combine with the 5V Trinket M0 and a remote fob for a little film prop FX.
So, I'm here for to find the circuit diagram or the full tutorial -- solenoid_driver.pdf -- link from the product description is a dead link? I found the controller chip from the youtube video, but it doesn't include the N channel FET or diode specs.
Does anyone have a link to that pdf? Or simply recognize this simple circuit and can pass along a diagram? I would greatly appreciate any assistance in this matter.
kidcopernicus
Re: Mini Push-Pull Solenoid - 5V
by millercommamatt on Mon Jul 08, 2019 2:43 pm
millercommamatt
by adafruit_support_bill on Mon Jul 08, 2019 2:44 pm
See the circuit diagram in this guide: https://learn.adafruit.com/robotic-xylo ... id-circuit
Links for the components can be found on the right side of your screen.
by kidcopernicus on Mon Jul 08, 2019 3:12 pm
Many many thanks!
I'm also going to attempt to power the circuit with a 5 AA harness, and trigger it with the Simple RF T4 Receiver and a 2 button keyfob, if I can. Wondering about problems with load. I'm a hack electrical engineer though, and I mean mindless butchery. Trying to concoct a remote button pusher..
But I'll have a look at those docs immediately.
Cheers! Great community here..
kidcopernicus
by kidcopernicus on Mon Jul 08, 2019 3:30 pm
Great information. I have the components identified and on order now, adafruit_support_bill.
matt, I wonder if that code will run on a Trinket 5V. It's a single, simple repetitive function in a very constrained volume, I'm trying to keep the electronics as small as I can.
Any insight on that? Just want to gather as much data as I can before build.
kidcopernicus
by millercommamatt on Mon Jul 08, 2019 6:44 pm
Code should work fine; just get the pin number correct for however you wire the Trinket.
millercommamatt
