Raspberry Pi Zero W - No WIFI
by COLORSH1FT on Fri Jul 19, 2019 9:23 pm
Hey support
I received my Raspi Zero W kit today and tested it out. It booted up no issues, but i could not get it to connect to my wifi. Is there anything i can do to try and fix this? Looking forward to your reply.
Thank you
COLORSH1FT
Re: Raspberry Pi Zero W - No WIFI
by franklin97355 on Sat Jul 20, 2019 1:56 am
What version of the OS are you running? If it is not the latest download the latest Raspbian Lite from the Pi foundation site and try that.
franklin97355
by COLORSH1FT on Sat Jul 20, 2019 8:25 am
Hey franklin97355,
My kit came with an 8GB SD card with the OS preloaded on to it, so that was the first reason I wrote you. I tried what you suggested: using balena etcher; I wrote Raspbian Buster Lite on the card. I booted up in terminal mode; figured out the user and pass, was able to "login". Once logged in, I stayed in the terminal; it never went through desktop set up. I wasn't sure what to do at that point, so for my own experimentation, i reformatted the card and etched the Raspbian Buster Desktop OS on to it. I was able to boot that up fine without a problem; but again it would not connect to my WIFI. My other Raspberry Pi (3 B+) has no issues connecting to this router. Is there anything else I should try?
Thank you for your time
COLORSH1FT
by adafruit_support_mike on Sat Jul 20, 2019 5:29 pm
Post the output from `dmesg` between CODE tags please. That will give us more information about the board's hardware recognition process.
by COLORSH1FT on Sat Jul 20, 2019 5:48 pm
Hey @adafruit_support_mike,
Here it is:
pi@raspberrypi:~ $ 'dmesg'
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.19.57+ (dom@buildbot) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1244 Thu Jul 4 18:42:50 BST 2019
[    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi Zero W Rev 1.1
[    0.000000] Memory policy: Data cache writeback
[    0.000000] cma: Reserved 8 MiB at 0x1b400000
[    0.000000] On node 0 totalpages: 114688
[    0.000000]   Normal zone: 1008 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 114688 pages, LIFO batch:31
[    0.000000] random: get_random_bytes called from start_kernel+0x8c/0x49c with crng_init=0
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 113680
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 bcm2708_fb.fbwidth=1360 bcm2708_fb.fbheight=768 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:DF:70:41 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=477bfeaf-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 434444K/458752K available (6954K kernel code, 635K rwdata, 2076K rodata, 464K init, 797K bss, 16116K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xdc800000 - 0xff800000   ( 560 MB)
                   lowmem  : 0xc0000000 - 0xdc000000   ( 448 MB)
                   modules : 0xbf000000 - 0xc0000000   (  16 MB)
                     .text : 0x(ptrval) - 0x(ptrval)   (6955 kB)
                     .init : 0x(ptrval) - 0x(ptrval)   ( 464 kB)
                     .data : 0x(ptrval) - 0x(ptrval)   ( 636 kB)
                      .bss : 0x(ptrval) - 0x(ptrval)   ( 798 kB)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] ftrace: allocating 25148 entries in 74 pages
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000031] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[    0.000081] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    0.000199] bcm2835: system timer (irq = 27)
[    0.000614] Console: colour dummy device 80x30
[    0.000643] console [tty1] enabled
[    0.000703] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[    0.060346] pid_max: default: 32768 minimum: 301
[    0.060906] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.060927] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.062359] CPU: Testing write buffer coherency: ok
[    0.063699] Setting up static identity map for 0x8200 - 0x8238
[    0.065115] devtmpfs: initialized
[    0.076639] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    0.077049] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.077081] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.078437] pinctrl core: initialized pinctrl subsystem
[    0.080007] NET: Registered protocol family 16
[    0.083381] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.091211] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.091228] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.091375] Serial: AMBA PL011 UART driver
[    0.094630] bcm2835-mbox 2000b880.mailbox: mailbox enabled
[    0.140005] bcm2835-dma 20007000.dma: DMA legacy API manager at (ptrval), dmachans=0x1
[    0.142704] SCSI subsystem initialized
[    0.142981] usbcore: registered new interface driver usbfs
[    0.143085] usbcore: registered new interface driver hub
[    0.143314] usbcore: registered new device driver usb
[    0.160975] raspberrypi-firmware soc:firmware: Attached to firmware from 2019-07-09 14:40, variant start
[    0.170996] raspberrypi-firmware soc:firmware: Firmware hash is 6c3fe3f096a93de3b34252ad98cdccadeb534be2
[    0.183521] clocksource: Switched to clocksource timer
[    0.287607] VFS: Disk quotas dquot_6.6.0
[    0.287740] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.288063] FS-Cache: Loaded
[    0.288419] CacheFiles: Loaded
[    0.308147] NET: Registered protocol family 2
[    0.309481] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes)
[    0.309549] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.309631] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[    0.309726] TCP: Hash tables configured (established 4096 bind 4096)
[    0.309894] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.309929] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.310333] NET: Registered protocol family 1
[    0.311427] RPC: Registered named UNIX socket transport module.
[    0.311441] RPC: Registered udp transport module.
[    0.311446] RPC: Registered tcp transport module.
[    0.311451] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.313815] hw perfevents: no irqs for PMU, sampling events not supported
[    0.313883] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[    0.318172] Initialise system trusted keyrings
[    0.318579] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    0.334336] FS-Cache: Netfs 'nfs' registered for caching
[    0.335658] NFS: Registering the id_resolver key type
[    0.335712] Key type id_resolver registered
[    0.335720] Key type id_legacy registered
[    0.335747] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    0.341426] Key type asymmetric registered
[    0.341445] Asymmetric key parser 'x509' registered
[    0.341555] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    0.342014] io scheduler noop registered
[    0.342030] io scheduler deadline registered (default)
[    0.342668] io scheduler cfq registered
[    0.342686] io scheduler mq-deadline registered (default)
[    0.342695] io scheduler kyber registered
[    0.345524] bcm2708_fb soc:fb: FB found 1 display(s)
[    0.372473] Console: switching to colour frame buffer device 170x48
[    0.391035] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 1360x768
[    0.395197] bcm2835-rng 20104000.rng: hwrng registered
[    0.395665] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[    0.396871] vc-sm: Videocore shared memory driver
[    0.397587] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
[    0.420141] brd: module loaded
[    0.435265] loop: module loaded
[    0.436218] Loading iSCSI transport class v2.0-870.
[    0.437252] usbcore: registered new interface driver smsc95xx
[    0.437288] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.465389] dwc_otg 20980000.usb: base=(ptrval)
[    0.665899] Core Release: 2.80a
[    0.665918] Setting default values for core params
[    0.665961] Finished setting default values for core params
[    0.866507] Using Buffer DMA mode
[    0.866522] Periodic Transfer Interrupt Enhancement - disabled
[    0.866530] Multiprocessor Interrupt Enhancement - disabled
[    0.866543] OTG VER PARAM: 0, OTG VER FLAG: 0
[    0.866666] Dedicated Tx FIFOs mode
[    0.867603] WARN::dwc_otg_hcd_init:1045: FIQ DMA bounce buffers: virt = db514000 dma = 0x5b514000 len=9024
[    0.867633] FIQ FSM acceleration enabled for :
               Non-periodic Split Transactions
               Periodic Split Transactions
               High-Speed Isochronous Endpoints
               Interrupt/Control Split Transaction hack enabled
[    0.867647] dwc_otg: Microframe scheduler enabled
[    0.867854] WARN::hcd_init_fiq:457: FIQ on core 0
[    0.867872] WARN::hcd_init_fiq:458: FIQ ASM at c04f9484 length 36
[    0.867902] WARN::hcd_init_fiq:497: MPHI regs_base at dc810000
[    0.867937] dwc_otg 20980000.usb: DWC OTG Controller
[    0.868045] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
[    0.868130] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
[    0.868188] Init: Port Power? op_state=1
[    0.868195] Init: Power Port (0)
[    0.868647] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    0.868667] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.868679] usb usb1: Product: DWC OTG Controller
[    0.868690] usb usb1: Manufacturer: Linux 4.19.57+ dwc_otg_hcd
[    0.868700] usb usb1: SerialNumber: 20980000.usb
[    0.869955] hub 1-0:1.0: USB hub found
[    0.870063] hub 1-0:1.0: 1 port detected
[    0.871275] dwc_otg: FIQ enabled
[    0.871290] dwc_otg: NAK holdoff enabled
[    0.871297] dwc_otg: FIQ split-transaction FSM enabled
[    0.871318] Module dwc_common_port init
[    0.871914] usbcore: registered new interface driver usb-storage
[    0.872411] mousedev: PS/2 mouse device common for all mice
[    0.874036] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    0.874530] bcm2835-cpufreq: min=700000 max=1000000
[    0.875308] sdhci: Secure Digital Host Controller Interface driver
[    0.875318] sdhci: Copyright(c) Pierre Ossman
[    0.875995] mmc-bcm2835 20300000.mmcnr: could not get clk, deferring probe
[    0.876751] sdhost-bcm2835 20202000.mmc: could not get clk, deferring probe
[    0.877008] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.877660] ledtrig-cpu: registered to indicate activity on CPUs
[    0.877815] hidraw: raw HID events driver (C) Jiri Kosina
[    0.878122] usbcore: registered new interface driver usbhid
[    0.878132] usbhid: USB HID core driver
[    0.879325] vchiq: vchiq_init_state: slot_zero = (ptrval), is_master = 0
[    0.881625] [vc_sm_connected_init]: start
[    0.892013] [vc_sm_connected_init]: end - returning 0
[    0.894006] Initializing XFRM netlink socket
[    0.894084] NET: Registered protocol family 17
[    0.894269] Key type dns_resolver registered
[    0.896441] registered taskstats version 1
[    0.896476] Loading compiled-in X.509 certificates
[    0.907808] uart-pl011 20201000.serial: cts_event_workaround enabled
[    0.907964] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
[    0.910985] mmc-bcm2835 20300000.mmcnr: mmc_debug:0 mmc_debug2:0
[    0.911006] mmc-bcm2835 20300000.mmcnr: DMA channel allocated
[    0.940983] sdhost: log_buf @ (ptrval) (5b513000)
[    0.991752] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    0.993784] of_cfs_init
[    0.993973] of_cfs_init: OK
[    0.995127] Waiting for root device PARTUUID=477bfeaf-02...
[    1.020229] random: fast init done
[    1.066421] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.068401] mmc0: Problem switching card into high-speed mode!
[    1.069406] mmc0: new SDHC card at address 0001
[    1.071202] mmcblk0: mmc0:0001 SD16G 7.45 GiB (quirks 0x80000000)
[    1.075221]  mmcblk0: p1 p2
[    1.084532] Indeed it is in host mode hprt0 = 00021501
[    1.154087] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[    1.154148] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[    1.293640] usb 1-1: new full-speed USB device number 2 using dwc_otg
[    1.293977] Indeed it is in host mode hprt0 = 00021501
[    1.536803] usb 1-1: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=12.09
[    1.536829] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.536841] usb 1-1: Product: USB Receiver
[    1.536851] usb 1-1: Manufacturer: Logitech
[    1.726013] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
[    1.731526] EXT4-fs (mmcblk0p2): 1 orphan inode deleted
[    1.731546] EXT4-fs (mmcblk0p2): recovery complete
[    1.807808] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.807906] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.810420] devtmpfs: mounted
[    1.815227] Freeing unused kernel memory: 464K
[    1.815243] This architecture does not have kernel memory protection.
[    1.815251] Run /sbin/init as init process
[    3.150350] systemd[1]: System time before build time, advancing clock.
[    3.394394] NET: Registered protocol family 10
[    3.396742] Segment Routing with IPv6
[    3.517483] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    3.518830] systemd[1]: Detected architecture arm.
[    3.551886] systemd[1]: Set hostname to <raspberrypi>.
[    3.578381] systemd[1]: Failed to bump fs.file-max, ignoring: Invalid argument
[    5.631005] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[    5.631062] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[    6.780387] random: systemd: uninitialized urandom read (16 bytes read)
[    6.806551] random: systemd: uninitialized urandom read (16 bytes read)
[    6.814108] systemd[1]: Created slice User and Session Slice.
[    6.814926] random: systemd: uninitialized urandom read (16 bytes read)
[    6.815747] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    6.834768] systemd[1]: Listening on Syslog Socket.
[    6.841129] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    7.608816] i2c /dev entries driver
[    8.666581] systemd[1]: Mounted Kernel Configuration File System.
[    9.023973] systemd[1]: Started Apply Kernel Variables.
[    9.230464] systemd[1]: Started File System Check Daemon to report status.
[    9.817247] systemd[1]: Started File System Check on Root Device.
[    9.869435] systemd[1]: Starting Remount Root and Kernel File Systems...
[    9.871011] systemd[1]: Started Journal Service.
[   10.971032] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   11.600307] systemd-journald[89]: Received request to flush runtime journal from PID 1
[   14.368280] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[   14.373504] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[   14.383977] [vc_sm_connected_init]: start
[   14.395648] [vc_sm_connected_init]: installed successfully
[   14.397615] media: Linux media interface: v0.10
[   14.672703] videodev: Linux video capture interface: v2.00
[   14.804216] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[   14.815169] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[   14.852426] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[   14.930399] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[   15.018235] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[   15.018261] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[   15.033878] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[   15.033907] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[   15.071819] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[   15.071842] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[   15.551421] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[   15.845680] bcm2835_audio soc:audio: card created with 8 channels
[   18.885020] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-20980000.usb-1/input2
[   19.029243] input: Logitech Unifying Device. Wireless PID:4055 Mouse as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.2/0003:046D:C52B.0003/0003:046D:4055.0004/input/input0
[   19.035887] hid-generic 0003:046D:4055.0004: input,hidraw1: USB HID v1.11 Mouse [Logitech Unifying Device. Wireless PID:4055] on usb-20980000.usb-1:1
[   19.040308] input: Logitech Unifying Device. Wireless PID:4016 Keyboard as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.2/0003:046D:C52B.0003/0003:046D:4016.0005/input/input4
[   19.042116] input: Logitech Unifying Device. Wireless PID:4016 Consumer Control as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.2/0003:046D:C52B.0003/0003:046D:4016.0005/input/input5
[   19.042556] input: Logitech Unifying Device. Wireless PID:4016 System Control as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.2/0003:046D:C52B.0003/0003:046D:4016.0005/input/input6
[   19.072091] hid-generic 0003:046D:4016.0005: input,hidraw2: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:4016] on usb-20980000.usb-1:2
[   19.350021] random: crng init done
[   19.350047] random: 7 urandom warning(s) missed due to ratelimiting
[   23.060989] input: Logitech Wireless Mouse as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.2/0003:046D:C52B.0003/0003:046D:4055.0004/input/input10
[   23.062581] logitech-hidpp-device 0003:046D:4055.0004: input,hidraw1: USB HID v1.11 Mouse [Logitech Wireless Mouse] on usb-20980000.usb-1:1
[   23.169529] input: Logitech K330 as /devices/platform/soc/20980000.usb/usb1/1-1/1-1:1.2/0003:046D:C52B.0003/0003:046D:4016.0005/input/input11
[   23.226201] logitech-hidpp-device 0003:046D:4016.0005: input,hidraw2: USB HID v1.11 Keyboard [Logitech K330] on usb-20980000.usb-1:2
[   31.777713] 8021q: 802.1Q VLAN Support v1.8
[   31.895692] uart-pl011 20201000.serial: no DMA platform data
[   32.907725] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   34.128716] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   35.110710] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
[   37.333794] Bluetooth: Core ver 2.22
[   37.334025] NET: Registered protocol family 31
[   37.334040] Bluetooth: HCI device and connection manager initialized
[   37.334077] Bluetooth: HCI socket layer initialized
[   37.334096] Bluetooth: L2CAP socket layer initialized
[   37.334179] Bluetooth: SCO socket layer initialized
[   37.406218] Bluetooth: HCI UART driver ver 2.3
[   37.406242] Bluetooth: HCI UART protocol H4 registered
[   37.427884] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   37.428325] Bluetooth: HCI UART protocol Broadcom registered
[   40.623286] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   40.623302] Bluetooth: BNEP filters: protocol multicast
[   40.623331] Bluetooth: BNEP socket layer initialized
[   41.396502] Bluetooth: RFCOMM TTY layer initialized
[   41.396541] Bluetooth: RFCOMM socket layer initialized
[   41.396587] Bluetooth: RFCOMM ver 1.11
[   58.723663] fuse init (API version 7.27)
[   97.379747] logitech-hidpp-device 0003:046D:4055.0004: HID++ 4.5 device connected.
[  109.887840] logitech-hidpp-device 0003:046D:4016.0005: HID++ 2.0 device connected.
pi@raspberrypi:~ $
Looking forward to your reply!
Reason: Please use code tags when posting code or logs to the forums. It preserves formatting and makes it easier for everyone to read the code. Click the code button above the reply box and paste your code between the tags created.
COLORSH1FT
by adafruit_support_mike on Sat Jul 20, 2019 8:01 pm
Thank you. That shows the OS recognizing the RasPi Zero-W correctly, and there's some configuration for the Wifi module.
What output do you get from `ifconfig -a`?
by COLORSH1FT on Sat Jul 20, 2019 9:17 pm
That command was not found:
pi@raspberrypi:~ $ 'ifconfig -a'
bash: ifconfig -a: command not found
pi@raspberrypi:~ $ 'if config-a'
bash: if config-a: command not found
pi@raspberrypi:~ $ 'ifconfig-a'
bash: ifconfig-a: command not found
pi@raspberrypi:~ $ 'if config -a'
bash: if config -a: command not found
pi@raspberrypi:~ $
Did i do this wrong? Let me know what you think.
COLORSH1FT
by franklin97355 on Sat Jul 20, 2019 10:38 pm
Try sudo ifconfig -a and don't use quotes.
franklin97355
by COLORSH1FT on Sun Jul 21, 2019 10:27 am
Hey @franklin97355
 pi@raspberrypi:~ $ sudo ifconfig -a
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
pi@raspberrypi:~ $
What do you think?
COLORSH1FT
by adafruit_support_mike on Sun Jul 21, 2019 2:50 pm
Thank you. That means the OS hasn’t configured the Wifi interface, and confirms a hardware problem.
Send a note containing a link to this page and your order number to support@adafruit.com. The folks there will get you a replacement Zero-W.
by COLORSH1FT on Sun Jul 21, 2019 3:07 pm
Will do. I really appreciate your help and quick response!
Thank you!!!
COLORSH1FT
