๐Ÿ“ฃ๐Ÿ“ช ๐Ÿšš Adafruit will not be shipping USPS orders Monday January 20, 2020 ๐Ÿ—“. Expedited USPS orders placed after 11am ET ๐Ÿ•š Friday January 17 will go out Tuesday January 21 ๐Ÿ“ฃ๐Ÿ“ช๐Ÿšš
Problems using the IR Optical Sensor with the Huzzah32
by flcharron on Mon Aug 12, 2019 1:28 pm
I am trying to create a tachometer like the one in the Pro Trinket Tachometer guide https://learn.adafruit.com/pro-trinket-tachometer/circuit-design using the same reflective IR Optical Sensor https://www.adafruit.com/product/2349.
I will be using a HUZZAH32 for the final product as it will require wifi access and pushing pixels to the 3.5" TFT feather.
I started with the same base sketch as the guide, used an UNO R3 for the prototype, glued a white paper square on the chuck of my cordless drill and the RPMs seem to be displaying correctly in the serial monitor. All is good!
However, when I try to port this to my HUZZAH32, I am getting all sorts of ridiculously high values. This is my first time using an ESP32 and I am wondering if someone can help me find the solution.
Here's my circuit; pretty much the same as the one in the guide except for:
- pin 21 for the interrupt
- 3v instead of 5v
- no 7 segment backpack
Circuit
And here's the code:
#define interruptPin 21
long lastUpdate = 0;               // for timing display updates
volatile long accumulator = 0;         // sum of last 8 revolution times
volatile unsigned long startTime = 0;   // start of revolution in microseconds
volatile unsigned int revCount = 0;      // number of revolutions since last display update
void IRAM_ATTR tach_interrupt();
   Serial.begin(115200);
   pinMode(interruptPin, INPUT_PULLUP);
   attachInterrupt(digitalPinToInterrupt(interruptPin), tach_interrupt, FALLING);
   if (millis() - lastUpdate > 1000) {      // update every second
      unsigned int rpm = 0;
      // divide number of microseconds in a minute, by the average interval.
      if (revCount > 0) {
            rpm = 60000000 / (accumulator>>3);
    Serial.print(rpm); Serial.println(" RPM");
    lastUpdate = millis();
    revCount = 0;
void IRAM_ATTR tach_interrupt() {
  // calculate the microseconds since the last interrupt
  long usNow = micros();
  long elapsed = usNow - startTime;
  startTime = usNow;  // reset the clock
  // Accumulate the last 8 interrupt intervals
  accumulator -= (accumulator >> 3);
  accumulator += elapsed;
  revCount++;
Again, pretty much the same as the guide except for:
- pin 21
- IRAM_ATTR attribute for ESP32 interrupts
- removed the 7seg code
Here is a sample serial output from my original UNO R3 test, beginning with my drill stopped, revving it up and back down.
0 RPM
0 RPM
0 RPM
93 RPM
126 RPM
496 RPM
662 RPM
711 RPM
774 RPM
830 RPM
902 RPM
861 RPM
816 RPM
0 RPM
0 RPM
0 RPM
And here is a sample output from the HUZZAH32, doing a similar test with my drill.
0 RPM
0 RPM
0 RPM
759493 RPM
340909 RPM
111111 RPM
50804 RPM
394736 RPM
0 RPM
0 RPM
0 RPM
Does anyone have an idea of where to look? Are there really way too many interrupts, and if so, for what reason?
flcharron
