Programming ADC on Attiny25
by raykholo on Fri Jun 04, 2010 9:52 pm
I am making a servo tester with the attiny25v microcontroller. I need help writing a function that will set up and perform an analog read (initializing adc registers, setting the timers, etc.) I use AVR Studio 4.
If anyone is interested, this servo tester will read a 10k pot and control the servo with that, and there will also be a pushbutton that will center the servo. And I was planning to "bit-bang" the servo pulses, but if anyone is aware of a super small library that will comfortably fit into the 2k of memory, please let me know.
Thank you.
raykholo
Re: Programming ADC on Attiny25
by adshea on Sat Jun 05, 2010 2:32 am
The ATTiny25 has a timer that you can use in "Output Compare" mode as a PWM generator. This will let you generate pulses without having to bit-bang them.
adshea
by raykholo on Sat Jun 05, 2010 8:16 am
AdShea wrote:The ATTiny25 has a timer that you can use in "Output Compare" mode as a PWM generator. This will let you generate pulses without having to bit-bang them.
Thank you. Is there a function such as PULSEOUT in the AVR Studio syntax?
raykholo
by Entropy on Mon Jun 07, 2010 11:33 am
Not sure if there is anything directly - I'd read the datasheet for information on ways you can configure the timer/counters to do what you need.
http://winavr.scienceprog.com/example-a ... g-avr.html should give you a start, but you'll have to take the register definitions and port them appropriately to the Tiny25 running at your selected clock frequency. (Exact register bits will be different, as will your prescaler values.)
Entropy
