SD card mate breakout
by kero905 on Thu Jun 10, 2010 12:03 am
I've been searching for a good SD card breakout board. For some reason sparkfun and others seem to get it wrong, charging $18 for a board that doesn't do level shifting. I like how the waveshield and other ladyada shields handle the buffering but wanted something that wasn't a shield, so I made a board from ladyada's posted layout. I've attached the eagle file.
Features 3.3V and 5V operation, buffered CS/SCK/MOSI/MISO broken out. other pins also broken out separately.
example use:
http://www.flickr.com/photos/keroism/4687227364/
All or most of the parts are from the wave shield: http://www.ladyada.net/make/waveshield/parts.html
IC1: MCP1700-3302E/TO
IC4: 74AHC125
C1: 100uF / 6V electrolytic
c2 + C3: 0.1uf ceramic
led: normal 3mm led
R10: around 470k
R6: 10K
SD card holder: Tyco 2041021-3
But I think this board takes too much breadboard space, so ill try to improve it later by putting the raw SD card pins on another side. Also note I am a noob and the board might have errors. This file is actually a correction of the PCB I had made, but I have not printed this ver so there might new errors. (I did double check it though)
sd_breakout.zip
eagle board + sch v0.02
(60.46 KiB) Downloaded 1254 times
kero905
Re: SD card mate breakout
by fat16lib on Thu Jun 10, 2010 9:12 am
I have had good luck with these SD/microSD adapters:
http://yhst-27389313707334.stores.yahoo.net/sdcaad.html
http://yhst-27389313707334.stores.yahoo.net/micaad.html
The microSD board is 1.4”x0.8” and the SD is 2.0"X1.3". They have an on-board 3.3V regulator and a 74LCX245 level shifter.
fat16lib
by adafruit on Thu Jun 10, 2010 9:51 am
if you can wait a few days - http://www.flickr.com/photos/ladyada/46 ... 9/sizes/l/ - is being pick & placed right now :D
by fat16lib on Thu Jun 10, 2010 11:20 am
Nice card!
Can it be? Looks like a five pin header from CS to GND could just plug into an arduino. Then you only need a wire to 5V.
CS -> SS -> pin 10
DI -> MOSI -> pin 11
DO -> MISO -> pin12
CLK -> SCK -> pin 13
GND -> Arduino GND pin next to pin 13
Does this work?
With six pins you could have CD.
fat16lib
by adafruit on Thu Jun 10, 2010 1:29 pm
good eyes :) yes we did that on purpose. unfortunately 5V isnt available on that side, so you have to wire that up
CD would go to pin 9 (its next to CS)
by kero905 on Thu Jun 10, 2010 2:50 pm
fat16
Those are some nice adapters. Wish I known about them before.
Oh.. I just saw your microsd breakout on the Jig how-to. Very nice! Grr wish I knew you were making one, I wouldn't even have bothered clobbering one up.
kero905
by adafruit on Thu Jun 10, 2010 3:25 pm
we didnt know till recently either :) yours looks great!
by kero905 on Thu Jun 10, 2010 6:18 pm
Thanks.. oh yeah.. I am currently working on a Xbee adapter board specific to the Tweet-a-watt. Basically I hacked up Adafruit Xbee adapter board to get rid of buffer and normal headers and add the voltage dividing resistors. The board is slightly smaller than the normal adapter and I guess it could be helpful if someone had to put together a bunch of Tweet-a-watts.
kero905
by adafruit on Sun Jun 13, 2010 1:02 pm
in case any one wanted a peek, its here!
http://www.adafruit.com/index.php?main_ ... cts_id=254
SD card lbn problem
by figo2100 on Fri Jul 16, 2010 3:57 pm
adafruit wrote:if you can wait a few days - http://www.flickr.com/photos/ladyada/46 ... 9/sizes/l/ - is being pick & placed right now :D
Hi there ,,,
Hope everything is fine ,,
I baught 1gb SD Cards from China and these cards have a problem when i try
to write any data its ok i can write the full capacity 981 Mb but the
problem appears when i try to open these files which i have wrote into SD
card it just read the files in the first 120 Mb i used i a SD card Checker
when i check samples from the cards its told me after 12% of the check THERE
IS ERROR IN (LBN)so i hope you help me how to solve this problem .
Best Regards
Ahmed
figo2100
Re: SD card lbn problem
by richms on Sat Jul 17, 2010 6:20 am
Hi there ,,,
Best Regards
Ahmed
Fix is simple, dont buy counterfeit cards that lie about their capacity.
richms
by figo2100 on Sat Jul 17, 2010 9:13 am
hello thx for your replay at first i want to explane for you its not a fake capacity i can write files with 1 gb but after 120 mb card cant read these files
figo2100
by richms on Sat Jul 17, 2010 9:23 am
That is what the fake cards do, the controller thinks it has a gig of flash connected, it really only has a lot less so that it will format and show capacity and then lose anything written to the portion beyond its capacity.
http://fightflashfraud.wordpress.com/ says it all
If you cant run h2test over the whole card then it is a fake. Most of the cheap ones sold on ebay are fake, they rely on people not finding out till after the limit to dispute with paypal is up so you cant do anthing about it.
richms
by figo2100 on Sat Jul 17, 2010 9:54 am
Hello
i tried to use H2testw v1.4 and this is the result so whats your opinion?
best regards
Ahmed
The media is likely to be defective.
121.9 MByte OK (249808 sectors)
859.0 MByte DATA LOST (1759280 sectors)
Details:859.0 MByte overwritten (1759280 sectors)
0 KByte slightly changed (< 8 bit/sector, 0 sectors)
0 KByte corrupted (0 sectors)
2 MByte aliased memory (4096 sectors)
First error at offset: 0x00000000077fa000
Expected: 0x00000000077fa000
Found: 0x000000003d3fa000
H2testw version 1.3
Writing speed: 5.66 MByte/s
Reading speed: 9.04 MByte/s
H2testw v1.4
figo2100
by richms on Sat Jul 17, 2010 10:07 am
You have a 128meg card faked to look like a 1 gig card.
If you got it recently then you may be able to file a paypal dispute, but most sellers load the postage which you normally dont get refunded, so even if you do return the card to them they have made money on the whole deal.
richms
