ESP32 left my PyPortal
by unawoo on Thu Jan 30, 2020 4:16 pm
i got two adabox 11 last march, i soon put my modified version of the weather program on one and it's still working today as good as ever.
i use the second to test out things, always worked. so yesterday i try the Cleveland Museum of Art program and i get this:
RuntimeError: Was not able to find ESP32.
so i made sure i was using the latest libraries and uf2, i was, then tried it with other programs that use the ESP32, same error.
i know enough electronics and software to believe that what i have is a hardware failure.
note that the board is fine physically and runs programs that don't use the ESP32 so i can still use it as a fine display board with all it's built in functions.
assuming that the board is out of warranty is there anyone there that knows of a failure point /part and can it be repaired/replaced?
unawoo
Re: ESP32 left my PyPortal
by adafruit_support_carter on Thu Jan 30, 2020 6:37 pm
It's odd that it would just stop working like that. Are you getting the CircuitPython firmware from here?
https://circuitpython.org/board/pyportal/
and libraries from here?
https://circuitpython.org/libraries
Does the same thing happen if you try the basic internet connect test here?
https://learn.adafruit.com/adafruit-pyp ... et-connect
by unawoo on Thu Jan 30, 2020 7:15 pm
i got the firmware and libraries from the same links.
ran the program you mentioned and got this:
RuntimeError: ESP32 timed out on SPI select
thanks for your quick reply
unawoo
by adafruit2 on Fri Jan 31, 2020 2:18 pm
you can try repairing it using this guide!
https://learn.adafruit.com/upgrading-es ... -one-board
adafruit2
Site Admin
by unawoo on Fri Jan 31, 2020 2:42 pm
tried it then loaded up circuitpython and get the same result.
unawoo
by adafruit2 on Fri Jan 31, 2020 2:55 pm
what's the serial output from esptool
adafruit2
Site Admin
by unawoo on Fri Jan 31, 2020 4:31 pm
installed the esptool on windows 10 and ubuntu but i cant figure out how to work it.
my portal shows up as COM10 in windows and ttyACM1 ubuntu,
can you give me a command line to try out?
unawoo
by adafruit2 on Fri Jan 31, 2020 11:34 pm
adafruit2
Site Admin
by unawoo on Sat Feb 01, 2020 12:32 am
just tried the flash and this is the result:
jean-guy@jg:~/Desktop$ esptool --port /dev/ttyACM1 --before no_reset --baud 115200 write_flash 0 NINA_W102-1.6.0.bin
esptool.py v2.6
Serial port /dev/ttyACM1
Connecting........_____....._____....._____....._____....._____....._____....._____
A fatal error occurred: Failed to connect to Espressif device: Invalid head of packet (0x08)
unawoo
by adafruit2 on Sat Feb 01, 2020 12:35 am
did you install the UF2 in the previous step?
adafruit2
Site Admin
by unawoo on Sat Feb 01, 2020 12:51 am
i did with no results
unawoo
by adafruit2 on Sat Feb 01, 2020 12:51 pm
mind trying in windows? its worth a shot :)
adafruit2
Site Admin
by unawoo on Sat Feb 01, 2020 1:47 pm
hi,
got the same thing using windows 10:
PS C:\Users\jg\Desktop> esptool.py --port COM10 --before no_reset --baud 115200 write_flash 0 NINA_W102-1.6.0.bin
esptool.py v3.0-dev
Serial port COM10
unawoo
by adafruit2 on Sun Feb 02, 2020 1:42 pm
huh ok weird - lets replace it. email support@adafruit with a link to this thread, for a new pyportal
adafruit2
Site Admin
by unawoo on Sun Feb 02, 2020 2:42 pm
thank you for the replacement, and a bigger one for going trough the testing with me.
i learned a lot from following your links and used my new knowledge to un-brick an esp32 feather i totally bricked two years ago.
you are a great teacher.
unawoo
