I have a small weather node I built using the following:
WeMos D1 Mini ESP Processor
BME280 Sensor
Went to add some functionality and got the notification that updates to the following were available:
AdaFruit BME280 library
AdaFruit Unified Sensor Library
Upgraded the Unified library to version 1.1.4 and my code still functioned
If I upgrade the BME280 library to any of the 2.x versions the BME280 library then the software can not detect
the BME 280 and the software fails.
The sensor is wired as I2C
Upgrade to Adafruit BME280 Library 2.x Fails
- lathemaster
- Franklin97355
Re: Upgrade to Adafruit BME280 Library 2.x Fails
Have you tried loading the earlier version?
- lathemaster
Yes I am currently up and running with the following:franklin97355 wrote:Have you tried loading the earlier version?
Adafruit BME280 Library Ver. 1.1.0
Adafruit Unified Sensor Library Ver. 1.1.4
All 2.x versions of the BME library fail to detect the sensor
- adafruit_support_carter
If you run this example with the latest version of the library:
https://github.com/adafruit/Adafruit_BM ... 80test.ino
what do you get in the serial monitor?
- adafruit2
@lathemaster - what is the exact url of the sensor you purchased?
