PWM Mode Question
PWM Mode Question
by soggybag on Thu Aug 26, 2010 5:27 pm
I'm using PWM in an application that uses audio. I can hear some high pitched noise, which I suspect is coming from the PWM. Right now I'm using the following to set up my PWM.
I'm using the ATTINY13. I'm wondering if it is possible to set the speed of the PWM to a frequency high enough to be out of audio range.
TCCR0A |= (1<<COM0A1) | (1<<WGM00); // PWM Phase correct mode 1
TCCR0B |= (1<<CS00);// --no prescale
soggybag
Re: PWM Mode Question
by zener on Sat Sep 04, 2010 2:55 pm
You might also try a low pass filter. Stick an inductor in the line, or try a LC filter.
zener
by adshea on Thu Sep 30, 2010 5:11 pm
What's your limit comparator set to? How fast is your clock? The AVR datasheets have an equation to give you the PWM frequency. If you want it to be inaudible you need it to be well above 25kHz.
adshea
