V-USB "USB Device not recognised"
by edwards.aus on Tue Sep 07, 2010 11:15 pm
Hi all,
I am having troubles with programming my ATMEGA88pa with V-USB software. I just get this extremely vague error "USB Device not recognised". I am using the hid-mouse software here (just a very simple project trying to get my computer to recognise the controller) with 12MHz crystal set. I know that this error is quite common and I have tried a variety of issues to get rid of it.
I tried almost all of ALAN's troubleshooting VUSB tips "http://vusb.wikidot.com/troubleshooting" to no avail :( .
I have attached my entire project (hid_mouse.zip) here, so you guys can have a look. I am using AVRStudio4 here with STK500. I have made changes to usbconfig.h to set the appropriate D+, D- pins, changed to a random product ID but 0x16c0 vendor ID, and set the self powered flag (i am using my laptop adapter for power).
In makefile I set appropriate fuses for external crystal of12MHz.
Basically, when I compile the project with the makfile I get a main.elf file that I just upload to the microcontroller via the ELF Production File format button on the programmer (as in upload_program.jpeg). I am uploading no other files to the controller.
I am uploading only main.elf
I have also taken an image (circuit_image.jpeg) of the circuit I am using (because I am quite new to vusb, there may be a hardware issues that I cannot foresee).
The way my circuit looks
Await your replies earnestly. :?
Thanks and Regards,
Edwards
hid_mouse.zip
Project HID_mouse
(121.38 KiB) Downloaded 148 times
edwards.aus
Re: V-USB "USB Device not recognised"
by chatham on Fri Sep 24, 2010 8:48 pm
I have no real idea what is the issue with your setup... V-USB can be a real pain to work with.
Anyhow, I'm using a 328p in my setup, and I could get the code to work for it when I compiled for a 168, but not for an 88. I don't know what the difference is, but try the attached 168 .hex and see if it will load onto your chip. Although it might not work correctly, it does give you a file that at least works on a very similar setup. I usually just do my code uploads via programming just the flash memory - so double check the fuses in the fuses tab in AVR studio.
One thing I'd suggest would be to add some small capacitors on both sides of the chips - some standard .1uF decoupling caps over each pair of VCC/GND pins.
Hope it helps!
hid_mouse_168.hex
(5.17 KiB) Downloaded 239 times
OpenChord.org - Open Source kits to let you play Guitar Hero with a real guitar, or build your own Wii/PS3/USB controllers.
chatham
