Four Outlet Power Relay Module version 2
by Whatismyname on Sun Jan 17, 2021 10:21 am
Hi, I want to control a computer power supply rated at 1600 Watts to turn off and on will the Four Outlet Power Relay be my solution?
Whatismyname
Re: Four Outlet Power Relay Module version 2
by DanGR on Sun Jan 17, 2021 11:35 am
amps = watts / volts
amps = 1600/120 = 13.3A
The switch is rated at 12A
A different solution will be needed.
DanGR
by adafruit_support_bill on Sun Jan 17, 2021 12:20 pm
Most computer power supplies have a soft on/off circuit. So it is not necessary to switch the entire 13+ amps. You just need to find the power control wire on the motherboard connector and pull it to ground to turn on the supply:
https://www.instructables.com/How-to-Tu ... thout-a-C/
by 42volts on Thu Feb 18, 2021 12:22 pm
1600 watts? You running a whole server rack on one power supply or something? Or just overkill to the max?
As suggested, find the 'ON' wire. No need for big power handling, and since its a "pull low to switch on", you can use a 5 cent N-channel FET like a 2n7000.
42volts
