When I try to download Adafruit SAMD boards, it keeps failing with the message:
Error downloading https://github.com/ARM-software/CMSIS_5 ... 4.0.tar.gz
I have tried uninstalling and reinstalling Arduino, restarting my computer.
Error downloading Adafruit SAMD boards
- adafruit_support_carter
Re: Error downloading Adafruit SAMD boards
Do you have trouble installing other Board Support Packages?
- mcarreira
I have installed the Arduino SAMD board without a problem
- mcarreira
adafruit_support_carter wrote:Do you have trouble installing other Board Support Packages?
I was able to install the Arduino SAMD board with no issue
OK, so not some basic network connection issue. You've added the link to the .json file in Additional Boards Manager URLs?
https://learn.adafruit.com/adafruit-fea ... roto/setup
As another test, can you open the link directly in a browser from your location?
- mcarreira
adafruit_support_carter wrote:OK, so not some basic network connection issue. You've added the link to the .json file in Additional Boards Manager URLs?
Yes, I added the link to the Additional URLs. I actually tried downloading that directly several times today, and each time I downloaded it, my computer could not unzip it with the attached error. This time, I downloaded using the link you gave me, and it failed to unzip with the same error. BUT then I tried again to unzip the download I had tried many times this afternoon and IT WORKED.
I have no idea why, I tried the same thing 60 times, and the 61st it happened to work. Now that I have been able to unzip this file, do I have to do something special when I try to install the adafruit board?
- Screen Shot 2021-01-25 at 4.08.55 PM.png (45.57 KiB) Viewed 779 times
- mcarreira
After being able to unzip that file, I tried installing the adafruit board again, and it failed again in the same way.mcarreira wrote:adafruit_support_carter wrote:OK, so not some basic network connection issue. You've added the link to the .json file in Additional Boards Manager URLs?
Not sure what is happening. We can't recreate the issue here. The Adafruit SAMD BSP downloads as excepted. It seems like something odd is happening with your Arduino setup. But it sounds like a manual download had solved the issue in your case as a work around.
- mcarreira
Now that I have manually downloaded that file, how can I install the adafruit samd board? I tried again and still got the same error. Somehow, it couldn't see that I had already downloaded that file.adafruit_support_carter wrote:Not sure what is happening. We can't recreate the issue here. The Adafruit SAMD BSP downloads as excepted. It seems like something odd is happening with your Arduino setup. But it sounds like a manual download had solved the issue in your case as a work around.
You'd need to go through the manual process again.
If you have another PC available, see if you can replicate the issue there.
- mcarreira
If I have been able to unzip the file manually, is there a way I can put that in a folder so that when I install the adafruit samd board, the file is already there?
I don't know what to do now that I have downloaded and uncompressed the CMSIS_5-5.4.0 folder. After trying to install the board again, it failed downloading on the same file.
- mcarreira
Here is additional information about my error:
- Screen Shot 2021-01-26 at 6.13.47 PM.png (207.83 KiB) Viewed 749 times
When you tried this did you also manually delete this directory?I have tried uninstalling and reinstalling Arduino, restarting my computer.
/Users/(username)/Library/Arduino15
- ericwtram
I am also having this exact problem. I have gotten errors for other files in this download, but I would just manually download them and they would go away, but the error regarding the CMSIS file keeps popping up regardless of me manually downloading that file.
Anyone have any luck resolving this issue?
- tw_cem
I am having the same issue, I think.
Attempting to install Adafruit SAMD Boards gives me this error.
- CaptureSAMD.JPG (53.97 KiB) Viewed 603 times
