Adafruit CLUE nRF52840
by caseyjr16 on Wed Feb 03, 2021 11:55 pm
I am working with a new microcontroller I recently received within the last month. Upon connecting a data transferring USB cable to the device, the data displays on the screen. Firstly let me start by saying the mu-editor does not download on my MacOS 'BigSur'. I'm using a 2015 model.
Now as for the issue: When I double click the reset button the screen freezes but the "CLUEBOOT" shows up in the finder. After a few seconds or so the entire device resets itself and ejects on its own prompting a notification...I'll leave screenshots. I have used a virtual VM for an attempted fix, no luck so far
Screen Shot 2021-02-03 at 10.55.56 PM.png (127.16 KiB) Viewed 164 times
Screen Shot 2021-01-14 at 11.28.05 AM.png (109.83 KiB) Viewed 165 times
caseyjr16
Re: Adafruit CLUE nRF52840
by dastels on Thu Feb 04, 2021 1:45 pm
That sounds right up to the part about it auto-reseting for no reason.
What do you mean by "the data displays on the screen"?
Also, "mu does not download"? It doesn';t download an install on your mac, or doesn't download code to the CLUE?
dastels
by caseyjr16 on Sat Feb 06, 2021 7:03 pm
*The data freezes on the screen after I double-tap the reset button leading to the microcontroller rebooting itself again.
I installed VM Fusion software on my Mac. Windows 10 is running on the VM and mu-editor downloads; however, none of the code written in the code.py file.
caseyjr16
by dastels on Sat Feb 06, 2021 8:56 pm
Is Mu saving your code elsewhere? Saving to your CLUE is simply just saving it to the CIRCUITPY drive. Mu is usually pretty good about finding and using that automatically.
dastels
by caseyjr16 on Sat Feb 06, 2021 10:25 pm
The screenshots I displayed above are the resources/tools I am working with when I start up the CLUE board, Dave.
Screen Shot 2021-01-27 at 6.02.43 PM.png (153.6 KiB) Viewed 126 times
caseyjr16
by dastels on Sun Feb 07, 2021 12:55 pm
Well, Mu knows it's using CircuitPython... but where is it saving the code? And what do you see in the REPL (click the "Serial" button to open the REPL pane).
dastels
by caseyjr16 on Sun Feb 07, 2021 6:44 pm
On the attached screenshot you can see where the file is saving and the REPL data is coordinating with the data displaying on the screen.
Screen Shot 2021-02-07 at 5.38.38 PM.png (30.98 KiB) Viewed 109 times
caseyjr16
by dastels on Sun Feb 07, 2021 8:49 pm
Ok, it's not saving to your CLUE. That would be CIRCUITPY (however it shows up on windows).
You can copy it to CIRCUITPY yourself or (probably) have Mu start saving it there for you.
dastels
by caseyjr16 on Mon Feb 08, 2021 5:44 pm
The clueboot does not show up until after the freezing issue.
caseyjr16
by dastels on Mon Feb 08, 2021 8:31 pm
You only need CLUEBOOT to install CircuitPython.
dastels
by caseyjr16 on Mon Feb 08, 2021 9:29 pm
Could you go more in-depth about this process?
Thanks.
I'm sending screenshots for this.
Screen Shot 2021-02-08 at 8.25.21 PM.png (247.34 KiB) Viewed 92 times
caseyjr16
by dastels on Mon Feb 08, 2021 9:57 pm
This guide goes over everything you need to get up and running with the CLUE in either CircuitPython or C++: https://learn.adafruit.com/adafruit-clue.
dastels
